AI Failure Detection
Bambuddy can periodically check your prints against a self-hosted Obico ml_api container and automatically act when a failure is detected (spaghetti, layer shift, loose debris, etc.). No Obico account, no cloud calls, no WebSocket — Bambuddy just hands the ML API the printer's snapshot URL and reads back a score.
Self-hosted only
This integration talks to your own Obico ML API over HTTP on your local network. Bambuddy does not connect to obico.io or any third-party service.
  1. While a print is running, Bambuddy hands the ML API your camera snapshot URL every N seconds (default 10s).
  2. The ML API fetches the snapshot itself and returns a list of detected defects with confidence scores.
  3. Bambuddy smooths scores over time (Obico's own EWM + rolling-mean math) so a single noisy frame cannot trigger an action.
  4. When the smoothed score crosses the High threshold, Bambuddy runs your configured action once for this print.
The smoothing uses a 30-frame warmup, an exponentially weighted moving average with alpha = 2/13, a short rolling mean (~5 min at 10 s/frame), and a long rolling-mean baseline (~20 h). This is the same approach Obico's own detector uses.
Setting Up the Obico ML API
You only need the ml_api container from Obico's stack. The web app, Django site, and printer registration are not required.
1. Clone the Obico server
git clone -b release https://github.com/TheSpaghettiDetective/obico-server.git
cd obico-server
2. Expose port 3333 (ml_api)
Edit docker-compose.yml and add a ports mapping on the ml_api service:
ml_api:
  ports:
    - "3333:3333"
3. Start the stack
docker compose up -d ml_api
The first start downloads the YOLO model (~100 MB) and allocates ~4 GB RAM.
4. Verify
curl http://<obico-host>:3333/hc/
# → "ok"
Configuring Bambuddy
Go to Settings → Failure Detection.
Required
  • Enable toggle — turns the detection service on.
  • Obico ML API URL — base URL to your ML API, e.g. http://192.168.1.10:3333. Click Test to ping /hc/.
  • External URL (set in Settings → General) — the URL the ML API will use to fetch Bambuddy snapshots. This must be reachable from the ML API container, not from your browser. Usually the IP of your Bambuddy host.
Tuning
  • Sensitivity — Low / Medium / High. Scales the confidence thresholds:
    • Low is less eager to trigger (fewer false positives, may miss early failures)
    • Medium is the default (Obico's original thresholds)
    • High triggers earlier but with more false positives
  • Poll interval — how often each active print is checked (5–120 seconds). 10 s is the Obico default.
  • Action on detected failure — what Bambuddy should do when the score crosses the high threshold:
    • Notify only — send a printer-error notification through your existing notification providers
    • Pause print — notify + send an MQTT pause command
    • Pause and cut power — pause + turn off any smart plug linked to that printer
  • Monitored printers — by default all connected printers are watched. Uncheck "Monitor all connected printers" to pick a specific subset.
Status card
The right column shows:
  • Whether the background service is running
  • The currently active thresholds (after sensitivity scaling)
  • Each active print's live classification (safe / warning / failure), smoothed score, and frame count
  • Recent detection history (timestamp, printer, class, score)
Requirements & Gotchas
  • The ML API container must be able to reach your Bambuddy host. It fetches snapshots by URL. If they're on the same Docker network or LAN, use Bambuddy's LAN IP. localhost only works if both run on the same host.
  • The External URL setting must be set. Without it, Bambuddy can't tell the ML API where to fetch snapshots.
  • The printer camera must be enabled and reachable — same requirement as Bambuddy's own camera page.
  • The action fires exactly once per print. After a detected failure, subsequent frames won't re-trigger until a new print starts.
  • Calibration prints are automatically skipped by Bambuddy's detection loop — the service only runs while a print is in the RUNNING state.
  • Disk / RAM — the ML model needs roughly 4 GB RAM on the Obico host. CPU use scales with how many printers you monitor and how short the poll interval is.
"external_url not set — ML API cannot reach snapshot endpoint"
Go to Settings → General and set the External URL to a hostname or IP the ML API container can reach.
Test button returns an error
Check the ML API is running (docker compose ps ml_api) and that port 3333 is exposed. Try curl from the Bambuddy host: curl http://<obico-host>:3333/hc/.
Service is running but no detections appear
No news is good news — entries are only written to the history when a detection is returned or the classification leaves "safe". Check the Status card to confirm the service is actively running and a print is in progress.
False positives on normal prints
Lower the Sensitivity setting (High → Medium → Low).
Actions didn't fire on an obvious failure
Raise the Sensitivity. Remember there's a 30-frame warmup at the start of each print (5 min at 10 s/frame), during which the service is deliberately quiet.
License & Attribution
Obico's ML model and detection algorithms are licensed under AGPL-3.0, the same license as Bambuddy. Bambuddy does not vendor or link any Obico code — it only calls the ML API over HTTP.
