External Links
Add custom links to external tools and resources in your Bambuddy sidebar navigation.
External links let you:
  • Quick access to related tools
  • One-click to Spoolman, OctoPrint, etc.
  • Customize your workflow
  • Keep everything accessible
  1. Go to Settings > External Links
  2. Click Add Link
  3. Fill in the details:
Field Description
Name Display name (e.g., "Spoolman")
URL Full URL including protocol
Icon Select an icon
Show in Sidebar Toggle sidebar visibility
Open in New Tab Open link in new tab
  1. Click Save
Reordering
Drag links to change their order in the sidebar:
  1. Hover over a link
  2. Grab the drag handle
  3. Drag to new position
  4. Release
Editing
  1. Click the edit icon on a link
  2. Modify any field
  3. Click Save
Deleting
  1. Click the delete icon
  2. Confirm deletion
Icons
Available Icons
Choose from Material Design icons:
Icon Name Good For
:material-spool: Spool Spoolman, filament
Printer OctoPrint, Mainsail
Chart Analytics, Grafana
Cog Settings, config
GitHub Repositories
Document Documentation
Home Dashboards
Link Generic links
Custom Icons
Additional icons available in the icon picker.
:material-sidebar: Sidebar Display
Visibility
Toggle Show in Sidebar to control visibility:
  • Shows in sidebar navigation
  • Hidden (accessible from settings)
Position
Links appear in the sidebar below the main navigation items.
Appearance
Links display with:
  • Icon (if selected)
  • Name
  • External indicator (if opens new tab)
Use Cases
Spoolman
Link to your filament inventory:
Field Value
Name Spoolman
URL http://192.168.1.50:7912
Icon :material-spool:
Sidebar Yes
New Tab Yes
OctoPrint / Mainsail
Link to printer web interfaces:
Field Value
Name Mainsail
URL http://192.168.1.100
Icon
Sidebar Yes
New Tab Yes
Grafana Dashboard
Link to monitoring dashboards:
Field Value
Name Grafana
URL http://grafana:3000/d/printers
Icon
Sidebar Yes
New Tab Yes
Documentation
Link to manuals or wikis:
Field Value
Name Docs
URL https://github.com/maziggy/bambuddy-wiki
Icon
Sidebar Yes
New Tab Yes
Printables / Thingiverse
Quick access to model sites:
Field Value
Name Printables
URL https://www.printables.com
Icon
Sidebar Yes
New Tab Yes
Admin Default Menu Order
Admins can set a default sidebar navigation order that applies to all users who haven't customized their own.
Setting a Default
  1. Arrange the sidebar items in your preferred order (drag to reorder)
  2. Go to Settings > General > Sidebar Order
  3. Toggle Set Default on
The current sidebar order is saved as the default for all users.
Scenario Behavior
New user Automatically gets the admin-set order
User hasn't customized Gets the admin-set order on next page load
User has customized Keeps their own order (admin default is not re-applied)
Admin toggles off Default is cleared; existing user orders are unchanged
The Set Default toggle is only visible to users with Settings: Update permission (settings:update).
One-Time Application
The default order is applied once per user. If you update the default, users who already received a previous default will not be affected. To re-apply, users can click Reset on their sidebar order first.
Keyboard Shortcuts
External links can be accessed via keyboard:
  • Links are assigned numbers after main navigation
  • Press the assigned number to navigate
Shortcut Assignment
External link shortcuts start after built-in page shortcuts.
Backup Integration
External links are included in backups:
  • Exported with database backup
  • Restored when importing backup
  • No manual re-entry needed
Backup & Restore
Related Tools
Add links to tools you use alongside Bambuddy for quick switching.
Open in New Tab
Enable "New Tab" to keep Bambuddy open while visiting links.
Organize by Usage
Put most-used links at the top via drag-and-drop.
Keep It Clean
Hide rarely-used links from sidebar to reduce clutter.
