Failure Analysis¶
Understand why prints fail by analyzing patterns across materials, printers, and settings.
Failure Dashboard¶
The Failure Analysis widget on the Statistics page shows:
Failure Rate¶
Overall success vs failure percentage:
Failure Trend¶
Track if failure rate is:
- Improving - Fewer failures over time
- Stable - Consistent rate
- Worsening - More failures recently
Correlation Analysis¶
Identify what's causing failures by analyzing correlations:
By Material¶
| Material | Success Rate | Failures |
| PLA | 95% | 3 |
| PETG | 88% | 8 |
| ABS | 75% | 12 |
| TPU | 70% | 6 |
Spot materials that need attention.
By Printer¶
| Printer | Success Rate | Failures |
| Workshop X1C | 92% | 5 |
| Office P1S | 85% | 10 |
| Garage A1 | 78% | 15 |
Identify problematic machines.
By Time of Day¶
| Time | Success Rate |
| Morning (6-12) | 91% |
| Afternoon (12-18) | 89% |
| Evening (18-24) | 88% |
| Night (0-6) | 85% |
Environmental factors may affect overnight prints.
By Duration¶
| Print Length | Success Rate |
| < 1 hour | 95% |
| 1-4 hours | 91% |
| 4-12 hours | 87% |
| > 12 hours | 80% |
Longer prints have more opportunities to fail.
Common Failure Modes¶
Adhesion Failures¶
Symptoms:
- Print detaches from bed
- Warping corners
- First layer issues
Correlations to check:
- Bed temperature settings
- Bed cleanliness (time since last clean)
- Material type (ABS/PETG more prone)
- Room temperature changes
Layer Adhesion¶
Symptoms:
- Delamination between layers
- Weak parts
- Cracks along layer lines
- Nozzle temperature
- Print speed
- Cooling fan settings
- Humidity (wet filament)
Stringing/Oozing¶
Symptoms:
- Strings between parts
- Blobs on surface
- Retraction settings
- Temperature (too high)
- Travel speed
Spaghetti¶
Symptoms:
- Tangled mess of filament
- Print knocked off bed
- Adhesion (root cause)
- AI detection (was it enabled?)
- Print complexity
Investigating Failures¶
Step 1: Filter Failed Prints¶
- Go to Archives
- Filter by Status: Failed
- Review the list
Step 2: Look for Patterns¶
Check what failed prints have in common:
- Same printer?
- Same material?
- Same time period?
- Similar settings?
Step 3: Compare with Success¶
Use Archive Comparison to compare a failed print with a successful one:
- Select a failed print and similar successful print
- Right-click > Compare
- Look for setting differences
Step 4: Document Findings¶
Add notes to failed archives:
- What you observed
- Suspected cause
- Changes made
Failure Tags¶
Tag failed prints for easier analysis:
| Tag | Use For |
adhesion-fail | Bed adhesion issues |
layer-fail | Layer adhesion issues |
spaghetti | Complete failures |
warping | Warping issues |
stringing | Quality issues |
Filter by tags to see specific failure types.
Photo Documentation¶
Add photos to failed prints:
- Open the failed archive
- Click Add Photo
- Upload images of the failure
Visual documentation helps:
- Remember what went wrong
- Share with others for help
- Track if fixes work
Improving Success Rate¶
Quick Wins¶
- Dry your filament - Wet filament causes many failures
- Clean your bed - Regular cleaning improves adhesion
- Level your bed - Run auto-leveling regularly
- Control temperature - Avoid drafts and temp swings
Medium-term Fixes¶
- Tune materials - Create profiles for each material
- Calibrate flow - Ensure correct extrusion
- Check hardware - Worn nozzles, loose belts
Long-term Solutions¶
- Track patterns - Use failure analysis regularly
- Document changes - Note what worked
- Preventive maintenance - Follow maintenance schedules
Don't Delete Failures
Keep failed prints in your archive - they're valuable data for analysis.
Consistent Tagging
Use consistent tags for failures to enable filtering and pattern detection.
Photo Everything
Photos of failures are invaluable for diagnosis and tracking improvements.
Check the Obvious
Most failures are due to: wet filament, dirty bed, or temperature issues.
One Change at a Time
When fixing issues, change one thing at a time to know what worked.
