Print Log¶
The Print Log provides a chronological table of all print activity across your printers, giving you a quick at-a-glance history of every print.
The Print Log is a dedicated view mode within the Archives page that focuses on print activity as a flat, filterable table. Unlike the standard archive views (grid, list, calendar), the Print Log shows one row per print event with key details at a glance.
Accessing the Print Log¶
- Go to the Archives page
- Click the Print Log button in the header toolbar (next to the grid/list/calendar view toggles)
Table Columns¶
Each row in the Print Log represents a single print event:
| Column | Description |
| Date/Time | When the print completed |
| Print Name | Name of the print (with thumbnail) |
| Printer | Which printer ran the job |
| User | Username who started the print (when authentication is enabled) |
| Status | Result badge (color-coded), with the failure-cause classification shown underneath when set |
| Duration | Total print time |
| Filament | Material type and color indicator |
| Filament Used | How much filament this run consumed, in grams |
| Actions | Per-row edit and delete buttons (see Per-row actions) |
Five more columns are available but hidden by default — switch them on with Choosing columns:
| Finished | When the print ended, as opposed to the Date/Time column's start |
| Cost | Filament cost for this run, in your configured currency |
| Energy | Power drawn during the run, in kWh. Needs a smart plug |
| Energy Cost | What that power cost |
| Wear Cost | Printer wear for this run: its duration at the printer's wear cost per printing hour |
These are per-run figures, not the archive's
Filament Used and Cost are measured for this print, not copied from the file's estimate: a print that failed part-way is scaled to the progress it reached, tracked spools are preferred over estimates, and a multi-plate project dispatched one plate at a time counts only the plate that ran. That is why a row can differ from the filament figure on the archive card, which is the whole file's total.
Energy and Energy Cost are written by a background task shortly after the print ends, so a run that just finished shows — for a moment before the measurement lands.
Sorting¶
Click any column header to sort the log by it, and click again to reverse. Dates, durations and amounts open on largest-first; text columns open A–Z. The arrow in the header shows which column is active and which way it runs, and your choice is remembered for next time.
Sorting applies to the whole log, not the page you are looking at — asking for the most expensive print returns the most expensive print, not the most expensive one of the 25 rows currently on screen. Changing the sort returns you to page 1.
Rows with nothing in the sorted column always come last, in both directions, so sorting by Cost or Energy never opens on a screenful of blanks.
Choosing columns¶
Click Columns above the table to pick which of the columns above appear, and in what order. Drag a row (or use the arrows) to reorder, and the eye icon to show or hide.
The choice is stored in your browser, so it is per-device rather than per-account — a second person using the same Bambuddy keeps their own layout, and clearing site data resets it. Reset in the picker restores the defaults.
Status Badges¶
| Status | Color | Description |
| Completed | Green | Print finished successfully |
| Failed | Red | Print encountered an error |
| Stopped | Orange | Print was manually stopped |
| Cancelled | Grey | Print was cancelled before finishing |
| Skipped | Purple | Print was skipped in the queue |
Filtering¶
Narrow down log entries using the filter controls at the top of the table:
| Filter | Description |
| Search | Free-text search across print names |
| Printer | Show entries from a specific printer |
| User | Show entries from a specific user |
| Status | Filter by result (completed, failed, stopped, cancelled, skipped) |
| Date From | Show entries from this date onward |
| Date To | Show entries up to this date |
Combining Filters¶
All filters can be combined. For example, show only failed prints from "Workshop X1C" in the last week by selecting the printer, status, and date range together.
Pagination¶
The Print Log supports configurable pagination for navigating large histories:
| Setting | Options |
| Rows per page | 10, 25, 50, or 100 |
| Navigation | Previous / Next page buttons |
The current page range and total entry count are displayed alongside the navigation controls.
Per-row actions¶
Every row in the Print Log has two action buttons on the right:
Edit (classification)¶
Click the pencil icon to classify the print run -- set or change the failure cause and status on a single entry.
| Field | Values |
| Status | Completed, Failed, Stopped, Cancelled, Skipped |
| Failure cause | Adhesion failure, Spaghetti / Detached, Layer shift, Clogged nozzle, Filament runout, Warping, Stringing, Under-extrusion, Power failure, User cancelled, No status update received, Stopped by the printer kill switch, Other |
The classification you pick here is what the Failure Analysis widget groups by, so updates flow into the dashboard charts immediately.
Works on orphan entries too
If a print failed before any archive was created (for example, a dispatch error or a manual log entry), there is no archive to edit through -- the Print Log row editor is the only way to classify those runs.
Delete (single row)¶
Click the trash icon to remove a single entry from the log. The entry's filament, time, and cost contributions drop out of Quick Stats in the same response cycle. The matching archive (if any) is not affected -- the log row is independent of the archive.
Permission gating
Both buttons honour the same ownership shape as archive edits. With ARCHIVES_UPDATE_OWN / ARCHIVES_DELETE_OWN you can only act on entries you created; ARCHIVES_UPDATE_ALL / ARCHIVES_DELETE_ALL see every entry.
Clearing the Log¶
The Clear button removes all log entries from the database.
Permanent Action
Clearing the log permanently deletes all log entries. This action cannot be undone.
Archives Are Not Affected
The Print Log is stored independently from your archives and print queue. Clearing the log only removes log entries -- your archived 3MF files, metadata, and queue history remain untouched.
Automatic Logging¶
Log entries are written automatically whenever a print completes. No configuration is required -- once archiving is active, print events are recorded in the log.
Independent Storage¶
The Print Log uses its own database table (print_log_entries), separate from the archives table. This means:
- Log entries exist independently of archives
- Deleting an archive does not remove its log entry
- Clearing the log does not affect archives
- The log stays reachable with no archives at all — purging every archive leaves the log and its history intact
- The log is lightweight and optimized for fast querying
Permissions¶
When authentication is enabled, the Print Log respects the following permissions:
| Action | Required Permission |
| View the Print Log | ARCHIVES_READ |
| Edit classification on a row you own | ARCHIVES_UPDATE_OWN |
| Edit classification on any row | ARCHIVES_UPDATE_ALL |
| Delete a single row you own | ARCHIVES_DELETE_OWN |
| Delete any single row | ARCHIVES_DELETE_ALL |
| Clear all log entries | ARCHIVES_DELETE_ALL |
API Access¶
List Log Entries¶
Query Parameters:
| Parameter | Type | Description |
search | string | Search print names |
printer_id | integer | Filter by printer ID |
created_by_username | string | Filter by username |
status | string | Filter by status (completed, failed, stopped, cancelled, skipped) |
date_from | datetime | Start of date range |
date_to | datetime | End of date range |
limit | integer | Number of entries per page (default 50, max 500) |
offset | integer | Pagination offset |
sort_by | string | Column to order by (default date). One of date, print_name, printer, user, status, duration, completed_at, filament, filament_used, cost, energy, energy_cost, wear_cost. Anything else returns 400 |
sort_dir | string | asc or desc (default desc). Rows with no value in the sorted column come last either way |
Example:
Update a Single Entry¶
Edit the classification (failure cause and/or status) or the note of one entry. Requires ARCHIVES_UPDATE_OWN for entries you created, or ARCHIVES_UPDATE_ALL for any entry.
Request body:
All fields are optional. To clear an existing classification send "failure_reason": "". notes is the print's own note, shown on its archive window beside the archive's note on the file; "" clears it.
| Field | Valid values |
failure_reason | "" (clear), adhesionFailure, spaghettiDetached, layerShift, cloggedNozzle, filamentRunout, warping, stringing, underExtrusion, powerFailure, userCancelled, noStatusUpdate, killSwitch, other |
status | completed, failed, stopped, cancelled, skipped |
Unknown values return HTTP 400 -- the canonical vocabulary above is enforced server-side.
Example:
curl -X PATCH -H "X-API-Key: your-key" -H "Content-Type: application/json" \
-d '{"failure_reason": "cloggedNozzle"}' \
"http://localhost:8000/api/v1/print-log/42"
Delete a Single Entry¶
Removes one entry from the log. The entry's filament, time, and cost contributions drop out of /api/v1/archives/stats on the same request cycle. The linked archive (if any) is untouched. Requires ARCHIVES_DELETE_OWN for entries you created, or ARCHIVES_DELETE_ALL for any entry.
Example:
Clear All Log Entries¶
Removes all log entries. Requires ARCHIVES_DELETE_ALL permission.
Example:
Quick Status Check
Use the status filter to quickly find all failed prints and investigate patterns.
Date Range Analysis
Set a date range to review a specific time period, such as "last week" or "this month."
Per-User Tracking
When authentication is enabled, filter by user to see each person's print activity.
Lightweight History
The Print Log loads faster than the full archive views since it only fetches tabular data without thumbnails and 3MF metadata.
