Server-Side Slicing (Slicer API)¶
Bambuddy can slice STL and 3MF files server-side using OrcaSlicer or Bambu Studio running headlessly inside Docker. The Slice button in File Manager, Archives, and the MakerWorld page dispatches a background job that produces a ready-to-print .gcode.3mf in the same folder — no desktop slicer install required.
This is opt-in, and it changes what the Slice action does rather than whether it is there. Without the sidecar, Slice hands the file to your locally-installed slicer over the URI scheme, exactly as the Open in Slicer button always has. With the sidecar on, the same action opens Bambuddy's own slice modal instead and the work happens on the server. The icon tells you which you will get: a cog for server-side slicing, an external-link arrow for the desktop handoff.
When to use it¶
- You run Bambuddy on a headless box (NAS, mini-PC, RPi 5) and want one-click slicing without bouncing through a desktop machine.
- You want re-slice on existing archives (e.g. swap filament, change layer height) and have the result land back in Bambuddy automatically.
- You downloaded a model sliced for one printer (a MakerWorld import, a 3MF from a friend) and want to re-slice it for a different printer model — just pick the target printer in the slice modal.
- You want a "Print" button on MakerWorld imports that goes straight to the printer instead of opening Bambu Studio.
If you only slice from Bambu Studio / OrcaSlicer on your workstation and use Bambuddy as a print log, you don't need this.
Platform requirements¶
Both sidecar images are published as pre-built linux/amd64 images on GHCR and Docker Hub. No local build is required — docker compose up -d pulls the image and starts the service.
| Sidecar | linux/amd64 | linux/arm64 (RPi 4 / 5, Apple Silicon Linux, ARM cloud VMs) |
orca-slicer-api (default profile) | yes — pre-built image | experimental — via amd64 emulation, see notes below |
bambu-studio-api (--profile bambu) | yes — pre-built image | experimental — via amd64 emulation, see notes below |
Bambu Studio itself is x86_64-only on every platform (Linux, Windows, macOS Intel/Rosetta) and there is currently no public indication BambuLab plans to ship native ARM64 builds. OrcaSlicer's community ARM64 AppImage extraction fails under QEMU build emulation, and even when it works the OrcaSlicer CLI has known bugs blocking most Bambu-authored 3MFs (see OrcaSlicer mid-2026 CLI breakage).
The option that runs at full speed: run the sidecar on a separate x86_64 host (mini-PC, NAS, old laptop, x86_64 cloud VM) and point Bambuddy at it via the Sidecar URL field. The sidecar does not need to run on the same machine as Bambuddy, and this stays the recommendation wherever a second machine is available.
If that is not an option, the amd64 sidecar images can be run on the ARM64 host itself under emulation. This is experimental: expect a 3 to 6 times slowdown depending on model complexity, and that figure was measured on an RK3588 board, which is at the fast end of ARM hardware — a typical ARM NAS will be slower still. Treat it as a stopgap until native ARM64 images ship, not as a replacement for the x86_64 host above. Additional setup to enable emulation is required and described below. These steps are only required for ARM64 hosts. Once this setup is completed, check the relevant quick start section for the next steps.
Additional requirements for linux/arm64 hosts (experimental)¶
The commands below will install two new components:
qemu-user-static— QEMU user-mode emulation binariesbinfmt-support— kernel support for running foreign binaries
Similar commands are available for distributions not listed here, but the package names may differ. The installation requires root privileges (prefix commands with sudo if necessary).
| Distribution | Command |
| Ubuntu/Debian | apt-get update and apt-get install qemu-user-static binfmt-support |
| Fedora / RHEL / CentOS | dnf install qemu-user-static qemu-user-binfmt |
A reboot may be required after installing the packages on some systems.
On appliance NAS platforms (Synology DSM, QNAP Container Station) there is usually no package manager to do this with. Docker can register the handlers itself instead, which works anywhere Docker runs:
This does not survive a reboot on every platform, so if the sidecars come back with exec format error after restarting the host, run it again.
Whichever route you took, confirm it worked before going further:
That must print x86_64. If it prints exec format error or fails to start, emulation is not registered and the sidecars will not start either.
Additional requirements for Apple Silicon hosts¶
Docker Desktop for Mac runs amd64 images out of the box, so no extra setup is normally required. It does that through either Rosetta or its bundled QEMU depending on your settings — both work for the sidecars, and Rosetta is the faster of the two.
Troubleshooting:
- Ensure Docker Desktop is up to date and running
- Ensure that the "Use Rosetta for x86/amd64 emulation on Apple Silicon" option is enabled in Docker Desktop settings
- Run the verification command above — it must print
x86_64
Linux running natively on Apple Silicon (Asahi and similar) is not Docker Desktop; follow the linux/arm64 instructions above instead.
Quick start¶
The sidecar lives in the optional slicer-api/ folder of the Bambuddy repo. It is a self-contained Docker Compose stack that pulls pre-built images from GHCR:
cd slicer-api/
cp .env.example .env # adjust ports if you like
# OrcaSlicer only (default profile):
curl http://localhost:3003/health
# Both slicers:
docker compose --profile bambu up -d
curl http://localhost:3001/health # bambu-studio-api
curl http://localhost:3003/health # orca-slicer-api
First start pulls pre-built images from GHCR (~110 MB OrcaSlicer, ~220 MB Bambu Studio). No local build, no git in the BuildKit worker — works on QNAP Container Station, Synology DSM, and any other Docker environment without git pre-installed.
On an ARM64 host, set up emulation first and add one line to .env before running the commands above — see Quick start differences for ARM64 hosts at the end of this section.
Sidecar image channel
The Compose file defaults to SIDECAR_TAG=latest (current stable). To pin to a specific version, set SIDECAR_TAG=bambuddy-X.Y.Z in .env — each Bambuddy stable release publishes a matching sidecar image tag (e.g. bambuddy-0.2.5).
Then in Bambuddy:
- Settings → Workflow → Slicer
- Pick your Preferred Slicer (OrcaSlicer or Bambu Studio) — this drives the API sidecar.
- Toggle Use Slicer API on
- Paste the Sidecar URL for the chosen slicer (defaults to
http://localhost:3003for OrcaSlicer,http://localhost:3001for Bambu Studio)
The Slice action on file cards now opens Bambuddy's slice modal instead of handing the file to your desktop slicer. See File Manager → Slice a file for what the action looks like in each mode.
Pairing the API slicer with a different desktop slicer
The Open in Slicer dropdown right below Preferred Slicer controls only the desktop URI handoff (the button that hands a file off to your locally-installed slicer GUI). It defaults to Same as API slicer — pick Bambu Studio or OrcaSlicer there if you want them to differ. Common case: slice via the Bambu Studio sidecar (more reliable on Bambu-authored 3MFs) while keeping your local "Open in Slicer" button on OrcaSlicer.
Quick start differences for ARM64 hosts¶
Only the Compose commands change; the Bambuddy settings above are the same. ARM64 needs the docker-compose.arm64.yml override, which pins both sidecars to the amd64 images so they run under the emulation registered in Platform requirements. Put it in .env rather than on the command line, so every later docker compose command keeps it:
cd slicer-api/
# Make every later `docker compose` command use the ARM64 override:
echo 'COMPOSE_FILE=docker-compose.yml:docker-compose.arm64.yml' >> .env
# Both slicers:
With that line in .env, every other instruction on this page works unchanged — the Updating section further down included. The alternative is to name both files on every single command (docker compose -f docker-compose.yml -f docker-compose.arm64.yml ...); the first bare docker compose pull or up -d after that silently drops the override, and the containers fail to start.
Ports¶
| Service | Default host port | Notes |
orca-slicer-api | 3003 | Bambuddy's virtual-printer feature reserves 3000 and 3002 |
bambu-studio-api | 3001 | First free port in that range |
Override with ORCA_API_PORT / BAMBU_API_PORT in slicer-api/.env.
Port conflicts with virtual printers
Don't change ORCA_API_PORT to 3000 or 3002. Those ports are owned by Bambuddy's virtual-printer listener and changing the slicer-api port to either will cause address already in use at startup.
Sidecar settings¶
Set these in slicer-api/.env and re-run docker compose up -d.
| Variable | Default | What it does |
SIDECAR_TAG | latest | Image channel — latest, daily, or bambuddy-X.Y.Z to pin |
ORCA_API_PORT | 3003 | Host port for the OrcaSlicer sidecar |
BAMBU_API_PORT | 3001 | Host port for the Bambu Studio sidecar |
MAX_MODEL_UPLOAD_MB | 512 | Largest model accepted for a slice. Raise it for very large multi-colour projects — see the upload-limit entry |
How it works¶
The Slice flow runs server-side in the background:
Click Slice
Bambuddy enqueues a job and returns 202 + job_id
├─► Modal closes immediately
├─► Toast tracker polls /api/v1/slice-jobs/{job_id}
Background task forwards source file + presets to the sidecar
│ (plus any designer settings you chose to keep, patched onto the process preset)
├─► Sidecar runs `OrcaSlicer-Soft --slice 1 --load-settings ... --load-filaments ... --outputdir ...`
Resulting .gcode.3mf saved to Bambuddy library / archives
Toast: "Slice complete" + library/archives list refreshes automatically
Jobs survive the lifetime of the Bambuddy process (kept in-memory for 30 minutes after completion). Restart Bambuddy and in-flight jobs are lost.
Picking presets¶
Slice opens a modal with Printer, Process, and one or more Filament dropdowns — populated from your imported Local Profiles, Cloud Profiles, and the slicer-bundled standard tier. The Filament rows render dynamically based on the picked plate's actual AMS slot usage:
- Single-color plate → one filament dropdown.
- Multi-color plate → one dropdown per AMS slot the print uses, each labeled
Filament N (PLA).
Every filament row carries a colour control to the right of its dropdown — a swatch and its hex value, styled like the dropdown itself. Click it to set the colour that slot prints in.
Pre-pick is automatic and tries to match what the file was prepared with:
- Printer and Process default to the preset names embedded in the source 3MF's
project_settings.config(what Bambu Studio / OrcaSlicer recorded when the project was saved), as long as those presets exist in one of your tiers. Files with no embedded slicer config — an STL, a plain model 3MF — fall back to a preset compatible with the selected printer. Among presets that are equally valid for that printer, the one nearest a 0.2 mm layer height wins —0.20mm Standardwhere it exists, the closest thing to it otherwise. Without that rule the list's alphabetical order decided it, and Bambu's naming puts the finest, slowest height first. - Each Filament dropdown auto-selects against your imported / cloud / standard presets by
(filament_type, filament_colour)match, biased toward presets compatible with the selected printer. Material is a hard filter, not a preference: a preset that states a different material than the plate asks for is never auto-picked while any alternative exists, so a PLA plate does not draw a PETG profile because the colour happened to line up. A preset that states no material stays eligible — unknown is not the same as wrong.
You can override any pick before slicing.
Finding a profile in a long list¶
Each dropdown is split into sections — Imported, Orca Cloud, Bambu Cloud, Standard — and every section is listed in the same order as the slicer's bundled profiles: Bambu, then Generic, then other brands, alphabetical within each, and in a filament list all real filaments before the support materials (Support, PVA, BVOH, HIPS). Names compare without regard to case and read numbers by value, decimals included, so 0.08mm comes before 0.2mm and PA6 before PA12.
Bambu Cloud lists your own cloud profiles and Bambu's stock ones. While you're signed in, a stock cloud profile that the sidecar also bundles appears once, under Bambu Cloud: the cloud copy is Bambu's current profile, while Standard is your preferred slicer's own bundle (with OrcaSlicer preferred, Orca's re-authored @BBL profiles). Bambuddy drops the Standard copy when it builds the preset list, so the automatic pick and Only loaded spools see one copy, and a pipeline or AMS slot saved with the Standard copy uses the cloud one, from the Slice dialog and from Run with pipeline alike. The one exception is a run started with an API key without the cloud scope: no one can fetch the cloud copy for it, so it keeps the stored Standard copy. Signed out, nothing is hidden.
Every dropdown carries a search button next to its label. It opens a box that narrows that dropdown as you type: a profile stays when every word you type appears somewhere in its name, in any order, so meta sunlu x1 finds SUNLU PLA Meta @Bambu Lab X1 Carbon 0.4 nozzle. Open the dropdown to see the matches: the closed dropdown keeps showing the selected profile. The section headings stay, and the profile currently selected is always listed, even when it doesn't match. The search also looks through the profiles held back behind Show all (other printers, spools that aren't loaded), which show up under their own heading. If nothing matches, the box says so. Press Esc or click the button again to close the box and see the whole list.
Sorting and search only change what the dropdown shows. The automatic pick still works through the lists in tier order.
Filament colour¶
Neither Bambu Studio nor OrcaSlicer stores a colour on a filament preset — colour is a property of the project, which their GUIs set from the plate, not of "Generic PLA Silk". So when Bambuddy hands the slicer a preset by name there is no colour attached to it, and the slicer falls back to its own built-in default, Bambu green (#00AE42).
That default used to end up in every internal-slicer result: a green plate thumbnail whatever filament you picked, filament_colour = #00AE42 in the G-code 3MF, and a Color mismatch warning in the Print dialog against the AMS slot the job had just been correctly mapped to.
The swatch on each filament row is where the colour now comes from. It is pre-filled with:
- The colour that slot was designed with, read from the source 3MF's own
project_settings.config. A project file saved by Bambu Studio, OrcaSlicer or downloaded from MakerWorld carries one per slot. - The preset's own
default_filament_colour, for imported OrcaSlicer profiles that define one. (Bambu's bundled profiles do not — none of them.) - Bambu green, for a source that has no colour anywhere: an STL, or a mesh-only 3MF exported from CAD. These are the cases where the swatch is the only place a colour can come from, which is why it is offered on single-filament sources too.
Click anywhere on the control to change it. Setting it to the colour you actually have loaded is what clears the Print dialog's colour mismatch, and it drives the plate thumbnail the slicer renders.
Where to look on an STL
An STL has one filament row, labelled simply Filament. The colour control is at the right-hand end of that row, beside the dropdown, reading #00AE42 — the slicer's own green. That is not a placeholder: it is exactly the colour the file would be sliced with if you changed nothing.
Slicing for a spool that isn't the designer's choice
The pre-fill preserves the model author's intent, which is the right default for a multi-colour print. If you are printing someone's two-tone model in the two colours you own, set both swatches before slicing — the mapping in the Print dialog then matches on the first try instead of asking you to confirm a mismatch.
Slicer Pipelines have no swatch of their own; a pipeline slice picks up the source file's designed colours, or the preset's default, through the same chain.
Profiles filtered by the selected printer¶
The Process and Filament dropdowns are filtered by the printer you pick. With a printer selected, presets that belong to a different Bambu model are left out of the list, and the label says how many — "3 hidden" — next to a Show all link that brings them back for that dropdown only. Show fewer collapses them again. Compatibility comes from a preset's own compatible_printers list — imported profiles, Orca Cloud profiles, and the sidecar's bundled profiles all carry one — falling back to the @BBL <model> suffix in its name for presets that don't. The nozzle size is compared too, so a 0.6-nozzle process doesn't appear for a 0.4-nozzle printer.
Why the declared list matters more than the name
Several Bambu printers have no preset named after them anywhere in the bundle. All ten of the P1S's process presets are named @BBL X1C and name the P1S only in compatible_printers; the X1, X1E and H2D Pro are in the same position. Reading the printer out of a preset's name alone therefore concludes a P1S has no usable process at all. Bambuddy reads the declared list from the sidecar's bundled listing, which needs a sidecar image from v1.2.6 or later — an older one doesn't report it, and Bambuddy falls back to the name.
Three things are never hidden:
- A preset with no detectable printer — a custom or renamed profile — stays in the main list. Absence of evidence isn't evidence of incompatibility, and hiding these would make your own imported profiles disappear.
- Whatever is currently selected. If you deliberately pick a preset from another printer and then collapse the list, it stays visible and selected rather than being silently dropped.
- Everything, when the filter would leave nothing. If no preset at all reads as compatible with the selected printer, the dropdown shows the full unfiltered list rather than an empty one. A visible preset for the wrong printer can be changed; an empty dropdown gives you nothing to act on.
Switching the printer re-filters both dropdowns immediately and re-picks any selection the change left incompatible. Re-slicing for a different printer is fully supported, so the filter is a default view rather than a restriction — Show all is always one click away.
Only online printers and loaded spools¶
When you slice away from the printer, the useful choices are the spools that are already in it. Two checkboxes above the Printer profile dropdown narrow the lists to that. Both are off until you turn them on, and your browser remembers them.
- Only printers that are online — the Printer profile dropdown lists the models that are connected right now, at every nozzle size. If the profile Bambuddy picked for you is for a model that isn't online, it moves to one that is: the file's own printer when that model is online, otherwise the 0.4 mm profile of an online model. A printer you picked yourself stays.
- Only spools that are loaded — each Filament profile dropdown lists the profiles of the spools loaded in the online printers of the selected model. The automatic pick for each slot is made from those spools. A profile you picked yourself stays.
Profiles the checkboxes hold back sit behind the same Show all link, in a Not online or Not loaded group. Bambuddy never filters down to an empty list. A printer profile whose model it can't read from the name, such as a renamed custom printer, always stays. When no printer is online, or no loaded spool matches a profile for the selected printer, the dialog says so and shows the full lists.
Each filament row also has a Pick button. It opens a Loaded spools screen with one section per online printer of the selected model:
- Each AMS is shown as its four slots, empty ones included, so it matches the unit.
- AMS-HT units follow, then an external spool when one is in the holder.
- Clicking a spool sets that row's profile and its colour, so the preview matches the spool.
- A spool with no profile for the selected printer is shown greyed out and can't be picked.
How a spool finds its profile, strongest first:
- The profile set for the slot in Bambuddy, the one shown on the printer card, when the slot hasn't been changed since and the profile is for the selected printer.
- The same profile for the selected printer. A profile set for an X1C finds the H2D copy with the same name when you slice for an H2D.
- A spool set up from the slicer or the printer's screen. Its brand text is used, so a Bambu "PLA Basic" spool finds Bambu PLA Basic, and a spool with no brand finds Generic <material>.
A profile that states a different material from the spool is never matched. Spools are matched by their profile, not by material alone, so a loaded PLA doesn't bring in every PLA profile.
Which printers you see here follows printer access, and the checkboxes only appear for users who may see printer status.
Re-slicing for a different printer¶
The Printer dropdown defaults to the printer the source 3MF was prepared for, but is not constrained to it. A 3MF sliced for an X1C can be re-sliced for an H2D (or any other model), and vice versa — pick the target printer and slice as normal. The slicer regenerates the G-code from scratch using the target printer's bed size, kinematics, nozzle count, and start/end G-code; only the model geometry and paint/colour assignments carry over from the source file.
This makes MakerWorld imports work regardless of which printer the model's creator used.
Cross-class re-slice (single-nozzle ↔ H2D)¶
Re-slicing between a single-nozzle printer (X1C, P1S, A1, P2S, …) and a dual-nozzle printer (H2D / H2D Pro) used to fail with cryptic slicer errors — "G-code in unprintable area of multi-extruder printers" when objects fell into the H2D's per-nozzle dead zones, or a hard slicer crash on multi-color projects. Bambuddy now detects the class change and auto-enables the slicer's arrange pass so objects laid out for the source bed are repositioned safely on the target. No extra setting; just pick the new printer and slice. (You can also request that pass yourself on any slice — see Auto-orient and auto-arrange.)
One related behaviour comes along for the ride:
- The re-sliced archive's card shows a sensible cover image. With
--arrangeon, the slicer doesn't always regenerate the per-plate preview; Bambuddy falls back to the source archive'splate_N.png(a render of what the same plate looked like on the source printer) so the card shows the model rather than a blank slot or MakerWorld marketing art.
Filament slots your plate doesn't use¶
In a multi-plate project each plate usually paints with only some of the project's filament slots. The slice dialog labels the others "— not used by this plate" and greys out their dropdowns — but the slicer still wants a profile for every slot, and it validates all of them.
So before slicing a single plate, Bambuddy replaces every unused slot's profile with the one from the plate's first used slot. That keeps the slot count (and the file's per-slot references) intact while making the loaded set both materially homogeneous and scoped to the target printer, so neither validator fires on a slot the G-code never touches:
- "the temperature difference of the filaments used is too large" — an ABS default sitting next to the PLA the plate actually prints with.
- "filament preset (slot N) is not compatible with printer …" — a profile saved for another printer (e.g. an
@Bambu Lab H2Dfilament baked into the source file) sitting in a slot your plate ignores.
This applies to every single-plate slice, not just cross-class re-slices. Slicing all plates skips it: across the whole project every defined slot is used by some plate, so each one's profile is honoured as picked.
Slice as designed (keep the file's embedded settings)¶
Normally the slice applies your picked Printer / Process / Filament presets, which override whatever the file's author baked into its embedded project_settings.config. That's what makes re-slicing for a different printer work — but it also means a MakerWorld model set up for, say, five walls comes out at your process preset's default instead.
When the source 3MF carries embedded settings and the printer you've picked matches the printer the file was designed for, the modal shows a Use the file's built-in settings checkbox. Tick it and Bambuddy slices with no preset override, so the designer's own wall count, infill, filament and other process settings drive the result:
- All four preset dropdowns grey out — printer, process, filament and bed type. They're bypassed on this path, so they're locked to make that obvious (and so changing the printer can't silently pull you off the design and hide the checkbox).
- Filament comes from the file too, not your AMS picks. If the file's filaments don't match what's loaded, map them on the printer or leave the checkbox off and pick your own.
- It's offered only when your printer matches the design's target model. Honouring embedded settings for a different model would place the object on the wrong bed — that's exactly the case the preset path is for — so the checkbox simply isn't shown when the printer differs.
All-or-nothing — for a merge, see below
"Use the file's built-in settings" gives you the designer's complete profile or yours, never a blend, and it is only offered when your printer matches the design's target. To keep some of the author's settings while slicing for your printer with your filament, use Settings the file's designer changed instead.
Process settings¶
Below the preset pickers, Process settings opens the full print-parameter tree — the same pages, groups and ordering Bambu Studio and OrcaSlicer show under Print Settings, because the structure, labels, tooltips, bounds and defaults are all extracted from the slicer's own sources rather than hand-picked.
Every field starts from what your picked process preset actually sets — Bambuddy asks the sidecar to flatten the preset's inheritance chain, so the values shown are the ones the slice will really use. If the sidecar is offline or too old to answer, the panel falls back to the slicer's built-in defaults and says which of those it is at the top. An older sidecar is the common case — the sidecar image is pulled as latest independently of your Bambuddy version, so a current Bambuddy can be talking to a sidecar that predates this feature. Pull a newer sidecar image and the real values appear.
Use it to adjust the preset you picked for one slice: bump the wall count, drop the infill, switch on supports, change a speed. Anything you don't touch stays exactly as the preset defines it, so a slice with an untouched panel is identical to one from before the panel existed.
On a reasonably wide screen the dialog splits into two columns — presets, filaments, bed type and layout passes on the left, the settings panel open in a column of its own on the right. On a narrow screen or a phone it stays a single column and the panel folds away behind its heading, so it doesn't bury the preset pickers.
- Simple / Advanced / Expert mirrors the slicer's own visibility tiers. Simple shows the settings most prints need; Expert shows everything.
- Search looks across every page at once, matching parameter names, labels and tooltip text.
- Changed settings are marked with a dot, and the header shows how many differ from the preset. Each row has a revert arrow, and the header has a Reset that clears the lot.
- Filament pickers show your actual filaments. Options that choose which filament prints a feature — support base and interface, and the per-region pickers on the Multimaterial page — list the filaments selected on the left by name and slot, instead of asking for a slot number. "Default" keeps the slicer's own behaviour of using whatever filament the region already uses.
- Greyed-out settings are ones the slicer itself disables in your current configuration — infill options with infill at 0%, ironing options with ironing off. Bambuddy evaluates the slicer's own enable rules, so the panel greys out the same fields the desktop app does. Where a rule can't be evaluated with certainty the setting stays editable rather than being hidden.
Notes¶
- Your settings win. They are applied after the source file's support configuration and after any designer's settings you carried, so an explicit choice here is never overridden.
- A 3MF that wants supports can keep them. Bambu's shipped process presets all have supports off, because that is a decision per print rather than per quality level. So when a 3MF's own settings switch supports on, that choice — along with its support and interface filament slots, and tree versus normal — can be carried onto the preset you picked, and a file exported with PVA in the interface slot still slices that way. Tick Enable support where it is marked from file, or use Use the file's built-in settings above the panel. The carry only ever switches supports on: a file that has them off leaves your preset's own support settings alone, so a preset that deliberately enables them is not overruled by a download that does not use them. Where a file records no deviations for you to tick at all — an OrcaSlicer export, for instance — its support configuration is carried without asking, as it always was. Either way an explicit choice in this panel wins, and the slice log names any setting that was carried.
- Settings are per slice. They are not saved to a preset or a pipeline; pick a different file and the panel starts from the preset defaults again.
- Mutually exclusive with "Slice as designed". That path sends no process preset for these to patch, so the panel greys out while it is on — still visible, but nothing in it applies.
Settings the file's designer changed¶
A 3MF published by someone else often carries deliberate deviations from the stock preset — 5 walls, 100% infill, a 0.1mm first layer. BambuStudio records exactly which keys those are inside the file, so Bambuddy can carry them onto the preset you picked instead of losing them to a re-slice.
They appear in this panel, against the options they belong to, each marked from file with a tick box for whether to use it.
Nothing is ticked for you. These ticks follow the Use the file's built-in settings checkbox above them: with it off, no setting comes out of the file unless you ask for it by name; with it on, the file drives the whole slice and every one of them shows ticked. A line at the top of the panel says how many settings the file changed and offers to take them in one click. Two groups it leaves for you to decide individually:
- Settings tuned to the designer's machine — speeds, accelerations, prime-tower geometry — marked designer's printer, because they can be plain wrong or out of range on yours.
- Layer height and first layer height, marked overrides preset. These are what the process preset you picked is: carrying a file's 0.2mm onto a preset you chose for its 0.08mm would slice at 0.2mm while the dropdown still read 0.08mm. Their tooltip shows the file's value next to your preset's, so ticking one is a deliberate choice.
Typing your own value into any option always wins over the file's.
Settings the file changed that this panel has no entry for are listed by name under Other settings from this file — they still apply, so they are shown rather than quietly dropped.
Only the process slot is carried; your filament picks are honoured as chosen. The whole thing is hidden on the "Slice as designed" path, which uses the file's embedded settings wholesale instead.
- Parameter names and descriptions are in English, even when the rest of Bambuddy is not. They come verbatim from the slicer's source, and there are several hundred of them; translating them is a separate job from translating Bambuddy's own interface.
Auto-orient and auto-arrange¶
Two checkboxes below the bed-type dropdown run the same layout passes as Bambu Studio's Auto orient and Auto arrange buttons, before the slice starts:
- Auto-orient objects turns each object onto the side that prints best. The slicer scores candidate rotations on overhang area, contour and unprintability, then rotates the object onto the winner. Typically the payoff is fewer supports and a shorter print — a test part here came out 8% faster with nothing else changed.
- Auto-arrange on the plate lays the objects out so they no longer overlap. This is the fix for a plate whose parts were dropped in on top of each other, and for a source file whose coordinates land off the edge of a smaller target bed.
Both are off by default and set per slice — they are not saved to your presets or pipelines. Both rewrite placement the file came with, so an author who laid a model flat on purpose keeps that unless you ask otherwise.
A few things worth knowing:
- They also apply on the "Slice as designed" path. Unlike the preset dropdowns and bed type, these act on the geometry rather than the print config, so they stay available whichever settings drive the slice.
- Auto-arrange is project-wide in the slicer. Combined with Slice all plates that would collapse every plate's objects onto a single bed, so Bambuddy slices each plate separately and merges the results — see the "Slice all plates" toggle below. Auto-orient has no such problem: it rotates objects where they stand and never moves one between plates.
- Cross-class re-slices arrange regardless. That case needs the arrange pass to avoid the H2D's dead zones, so leaving the box unticked doesn't switch it off there.
- Several STLs on one plate. The sidecar takes one model per slice; to slice separate STLs (or copies of one) together, combine them into one 3MF first. The slice modal then opens with auto-arrange already ticked.
Plate picker¶
For multi-plate 3MFs the modal shows a plate picker first; pick the plate you want to slice, then the preset dropdowns appear for that plate's filament needs.
"Slice all plates" toggle¶
Multi-plate projects — parted statues, multi-part kits, calibration stacks — get a Slice all N plates checkbox in the action bar. With it on:
- Filament dropdowns expand to the union of every plate's slot needs (a slot a plate-2 part paints with but plate 1 doesn't is now selectable; without the toggle the modal only showed the picked plate's slots).
- The action button label flips to "Slice all N plates".
- The slicer produces a single
.gcode.3mfwith every plate's G-code inside (one Bambuddy archive, all plates). - Whenever the arrange pass is on — because you ticked auto-arrange, or because this is a cross-class re-slice — Bambuddy loops per plate behind the scenes (the slicer's
--arrangeis project-wide and would otherwise consolidate every plate's objects onto one bed) and merges the per-plate outputs into one multi-plate 3MF locally. The progress toast shows "Plate 2 of 5 — Generating G-code (47%)" through the loop. Wall-clock cost is roughly N × the per-plate slice time.
The toggle is hidden on STL / single-plate sources where it'd be meaningless.
How Bambuddy knows the per-plate filament list¶
| Source | When | Speed |
slice_info.config | The 3MF was already sliced by Bambu Studio | Instant |
| Preview-slice | Unsliced project file | 3–30 s first time, instant on repeat |
| Painted-face data | Sidecar unreachable (fallback) | Instant |
For unsliced project files Bambuddy runs a fast preview-slice via the sidecar to discover the canonical filament list (the slicer's own logic determines which painted regions the print actually uses). Results are cached per (file, plate) keyed on file content, so opening the modal a second time on the same plate is instant. If the sidecar can't be reached, Bambuddy falls back to scanning the painted-face quadtree data with a noise threshold — less precise but better than zero filaments.
For 3MF inputs that already carry embedded settings (e.g. exports from Bambu Studio or OrcaSlicer), Bambuddy still applies your selected presets — but if the sidecar's CLI rejects that combination (see the OrcaSlicer caveat in Troubleshooting), it transparently retries using the 3MF's embedded settings instead. Either way the result is flagged with used_embedded_settings: true in the job state so you can tell which path won — this is the same flag set when you deliberately choose Slice as designed.
Tier priority¶
Inside the SliceModal, dropdown sections are ordered Imported → Orca Cloud → Bambu Cloud → Standard, with auto-pick respecting the same priority when no metadata-aware match is found. Imported profiles win over cloud because they ship with parsed type / colour metadata, while cloud entries are listed by name only (Bambu Cloud rate-limits per-preset content fetches at the scale most users have). When a preset name appears in multiple tiers, Bambuddy backfills the cloud entry's metadata from the imported entry so cross-listed profiles still get auto-picked correctly. A bundled profile is left out of Standard when Bambu's stock cloud list has the same name, for auto-pick as well as the dropdowns, so it is picked and shown from Bambu Cloud (see Finding a profile in a long list). The standard tier is the slicer sidecar's stock bundled profiles — the unconditional fallback if nothing else resolves.
The standard tier carries full metadata of its own. A bundled preset states its material and its compatible printers on an ancestor rather than on the preset itself — Bambu ABS @BBL A1 inherits Bambu ABS @base, which inherits fdm_filament_abs, and only the last of those says ABS — so the sidecar resolves both through the inheritance chain before listing them. A profile whose parent can't be found is listed with no material rather than dropped, and stays eligible for auto-pick.
The standard tier lists every preset the slicer itself offers for a Bambu printer:
- Third-party filaments for Bambu printers, such as COEX PLA @BBL X1C or SUNLU PLA Matte @BBL X1C. The slicer keeps these in per-brand folders.
- OrcaSlicer's filament library (OrcaSlicer sidecar only): filaments such as Elegoo PLA @System that suit any printer. As in OrcaSlicer, one is offered on every Bambu printer except those where a filament made for that printer replaces it, so Generic PLA @System doesn't show on an X1 Carbon, which has Generic PLA @BBL X1C. Bambu Studio has no such library.
The order of the list matters: when several presets fit a plate equally well, the automatic pick takes the first. Within the slicer's own presets, and again within the library, real filaments come before support materials, then Bambu Lab, then Generic, then other brands, alphabetical within each. A PLA plate therefore gets Bambu PLA Basic rather than a brand that merely sorts earlier, and a PA plate gets Generic PA rather than Bambu Support For PA/PET. The library comes after all of the slicer's own presets. Colour is never among the resolved fields: no bundled profile carries one at any depth, because colour belongs to the project rather than to the preset — see Filament colour.
Slicer Bundles (removed in 0.2.4.7)¶
Bundle import as a managed unit — the old Settings → Slicer → Slicer Bundles panel that let you upload a .bbscfg and pick its printer + process + filament triplet from a single dropdown — was removed in 0.2.5. The panel itself was left in place as a notice for one release cycle and is now gone from Settings entirely.
Why: Bambu Studio's .bbscfg export strips the system process and filament presets it relies on, so an imported bundle left users without working process presets and slicing silently fell back to the 3MF's embedded settings on STL inputs. Bundle mode also hid the standard tier behind a constrained dropdown.
Use these instead:
- Individual preset imports — the same
.bbscfg/.bbsflmt/.orca_filament/.zip/.jsonfiles still import their contained presets through Local Profiles (each preset lands in its own slot and is picked through the normal Printer / Process / Filament dropdowns) - Orca Cloud Profiles — sync OrcaSlicer's cloud-synced triplets directly
- Cloud Profiles — Bambu Cloud presets, when you have the account
Slice-time lookup order is Imported → Orca Cloud → Bambu Cloud → Standard (see Tier priority above), unchanged across cloud and standard paths.
Where slice results land¶
| Source kind | Destination |
| Library file | New .gcode.3mf in the same folder as the source |
| Archive | New archive with the printer/project metadata copied from the source, name suffixed (re-sliced) |
| MakerWorld | After import, behaves like a Library file slice |
Sliced output is always exported as .gcode.3mf (not plain .gcode) so File Manager can pull the embedded thumbnail. The badge shows GCODE (blue), and the displayed filename matches the source's print name when set.
"Failed to slice the model"¶
The sidecar wraps the CLI's stderr but doesn't surface it on the API by default. Re-run inside the container to see the underlying error:
docker exec orca-slicer-api /app/squashfs-root/AppRun --slice 1 \
--load-settings "/path/to/printer.json;/path/to/preset.json" \
--load-filaments /path/to/filament.json \
--allow-newer-file --outputdir /tmp/out /path/to/model.3mf
/health reports version: "unknown"¶
Cosmetic. The bundled binary works fine; the wrapper just couldn't parse the version string from the slicer's --help output. Bambu Studio uses a different --help format than OrcaSlicer (which is what the wrapper was originally tuned for).
The same wrapper bug also reports the checks field as orcaslicer for both sidecars (including bambu-studio-api). Both are cosmetic and don't indicate the wrong image — use the steps in the next section to confirm freshness.
"input preset file invalid" / CLI returns -5 when slicing via a Cloud preset¶
Some Bambu Cloud and Orca Cloud filament presets ship with type set to "printer" / "print" and a routinely-empty from field; the Bambu Studio CLI's --load-settings parser rejects both as invalid. From 0.2.5, Bambuddy normalises both fields per slot before sending the payload to the sidecar — type is forced to match the slot (filament / process / printer) and from is pinned to "system". Pull the current Bambuddy image to pick up the fix; no sidecar action required.
A big model fails partway through slicing¶
From 1.2.6 a slice is only abandoned when the slicer goes quiet, not when it takes a long time. Bambuddy polls the sidecar for progress once a second, so a heavy model that keeps reporting is left alone however long it needs; the clock only runs while nothing is being reported.
Slicer stall timeout under Settings > Workflow > Slicer sets how long that silence may last, defaulting to 15 minutes. Raise it if you slice models that go quiet for long stretches between progress updates.
If a slice does time out, the message says so and points at this setting. That is a different failure from "Slicer sidecar unreachable", which means the sidecar could not be contacted at all — see the entry below.
Sidecars that do not report progress
Older sidecars have no progress endpoint, so there is no way to tell a slow slice from a stalled one. For those the same setting bounds total slicing time instead. Updating the sidecar restores the distinction.
Before 1.2.6
The limit was a fixed five minutes of total slicing time, and hitting it was reported as Slicer sidecar unreachable — the same message as a real connection failure. If you chased a sidecar problem that turned out not to exist, this was why.
Slice job stays "queued" forever¶
Check the Bambuddy logs for connection errors to the sidecar URL. Common causes:
- Sidecar container not running (
docker compose psto verify) Sidecar URLfield in Settings doesn't match the actual host/port- Bambuddy is running in Docker on a different network than the sidecar — use the host's LAN IP instead of
localhost
The slicer CLI rejects a field as "not in range"¶
Bambu Studio writes "inherit / unset" markers into a project's embedded settings: -1 on a handful of process fields, and 0 on the three feature-filament indices (wall_filament, sparse_infill_filament, solid_infill_filament, meaning "use whichever filament the object is set to"). Whether a slicer CLI accepts them depends on its build — OrcaSlicer 2.3 and earlier counted the filament indices from 1 and reject 0, while 2.4 and Bambu Studio accept it. The check runs on the embedded settings before the profiles Bambuddy passes are applied, so a rejected marker fails the slice no matter what you picked in the modal.
From 1.2.6 Bambuddy removes those markers from the copy it hands the sidecar, on the real slice and on the automatic plate preview alike, and the slicer falls back to its own default for the field. If you still see this error, the field is not in the allowlist yet — open an issue quoting the line, which names it. Pinning a current sidecar image is worth doing anyway: the tags are versioned, so an install set up long ago can still be running an old slicer.
A STEP file has no Slice button¶
Server-side slicing takes STL and 3MF only. Neither slicer can load a STEP from its command line — OrcaSlicer 2.4.2 and Bambu Studio 02.07.01.62 both answer Unknown file format. Input file must have .stl, .obj, .amf(.xml) extension. — so from 1.2.6 the button is hidden rather than offered and then failing after the upload.
Open in Slicer still works on STEP files when the handoff targets OrcaSlicer. Open the STEP there, export it as STL or 3MF, and the exported file slices server-side as normal.
With Bambu Studio as the desktop target the button is not offered on a STEP, or on an STL. That is a limit of Bambu Studio's URI handler, not of the application: it loads only .3mf from a link and refuses anything else with Download failed, unknown file format. before it even fetches the file. Until 1.2.6 Bambuddy offered the handoff anyway and the failure looked like a broken model. If you want the handoff for STL or STEP, set Open in Slicer to OrcaSlicer — it can stay on Bambu Studio for Preferred Slicer, the two are separate settings. Otherwise, open the file in Bambu Studio yourself and save it as a 3MF.
"File too large" / the model exceeds the sidecar's upload limit¶
The sidecar caps the size of a model it will accept. From the 1.2.6 images that cap is 512 MB and configurable; older images were fixed at 100 MB and reported the rejection as a bare HTTP 500 File too large, which looks like a slicer crash and is what #2802 was.
This is not a proxy setting
No reverse-proxy body limit affects it, and neither do MAX_FILE_SIZE, BODY_PARSER_LIMIT or EXPRESS_PAYLOAD_LIMIT — the sidecar reads none of those. The cap is enforced inside the sidecar container. See the entry below for the proxy case, which is a genuinely different failure with a different fix.
To raise it, set MAX_MODEL_UPLOAD_MB in slicer-api/.env and restart the stack:
cd slicer-api/
echo "MAX_MODEL_UPLOAD_MB=1024" >> .env
docker compose up -d # add --profile bambu if you run the Bambu Studio sidecar
If Bambuddy tells you the sidecar image predates the configurable cap, update it first — there is no variable to set on those:
Name the service, or the Bambu Studio sidecar is skipped
Substitute bambu-studio-api in both commands if that is the sidecar you slice with. Naming it is not optional: bambu-studio-api sits behind a compose profile, and a bare docker compose pull skips profile-gated services without saying so. You get "up to date", restart: unless-stopped keeps the old container running, and nothing changes.
docker compose --profile bambu pull works too, but on an OrcaSlicer-only host it downloads the 220 MB Bambu image and the following up -d starts a sidecar you never wanted.
Each slice now logs the model's size (Slicing <file> (142.7 MB) plate=1 …), so a support package shows at a glance whether a failure was a size rejection.
"413 Request Entity Too Large" when slicing¶
The slice request bundles your model plus the printer / process / filament profiles into one upload, so the body is several MB. If you put the sidecar behind a reverse proxy, that proxy — not the sidecar — rejects the upload with 413 when its request-body limit is too low. Bambuddy surfaces this as a failed slice job with a message pointing you here.
Bambuddy tells the two apart for you: a rejection from the sidecar's own cap names MAX_MODEL_UPLOAD_MB (see the entry above), while this one names client_max_body_size and the proxy.
Fix it on the proxy that sits directly in front of the sidecar (a common mistake is raising the limit on the proxy in front of Bambuddy instead — that one never sees the slice upload):
- nginx / SWAG / Nginx Proxy Manager: set
client_max_body_size 512M;in the sidecar'sserver(orlocation) block, then reload nginx. NPM: Advanced → Custom Nginx Configuration. - Traefik: the default has no body cap; if you added a
bufferingmiddleware, raisemaxRequestBodyBytes. - Cloudflare / other CDN in front: note the platform's own request-size cap (Cloudflare's free plan is 100 MB) — and prefer not proxying the sidecar through a public CDN at all; point Bambuddy straight at the sidecar's LAN address instead.
The simplest setup avoids the problem entirely: run the sidecar on the LAN and put its http://host:port directly in the Sidecar URL field — no reverse proxy needed.
Sliced file is tiny / "not a valid 3MF" / prints nothing¶
A symptom of a broken or misconfigured sidecar: the slice "succeeds" but produces a tiny file (e.g. 28 bytes) that does nothing, or fails at print time. This happens when the sidecar — or a proxy in front of it — returns HTTP 200 with a body that isn't a real 3MF (a stock/wrong sidecar image, a proxy error page, a truncated response, or an OrcaSlicer/Bambu Studio CLI crash that emitted no output). From 1.2.6 Bambuddy validates the slicer's output and fails the job with a clear error instead of storing that blob and letting it reach the printer. If you hit it:
- Confirm the Sidecar URL points at a real slicer sidecar and
curl <url>/healthreturns JSON (not an HTML error / login page). - Use the recommended Bambu Studio sidecar image (see Sidecar source); a
/profiles/bundled → 404in the logs means the image predates the Bambuddy fork's endpoints. - If reverse-proxied, check the proxy isn't returning an error page or buffering/truncating the response — and see the 413 entry above.
The print starts but nothing extrudes / no preparation stage is shown¶
The job dispatches, the bed reaches temperature and the toolhead moves, but the layer counter stays at 0, the AMS never loads, and the printer shows no preparation step. Update the sidecar image — this is a resolver defect fixed on the sidecar side, so updating Bambuddy alone does not clear it:
Most of a Bambu printer's setup lives in its start G-code: the M620 commands that ask the AMS to load a filament, and the M1002 gcode_claim_action calls that tell the printer which preparation step to report. Bundled Bambu presets keep that block in a companion profile the preset itself does not reference, and sidecars before this fix did not read it — so a slice came out with a short generic block instead, and a print with no start G-code heats up and moves without ever loading filament. The ams_mapping Bambuddy sends is unaffected and cannot compensate: it names which tray backs which slot, but something still has to ask the AMS to load it.
It affected every Bambu model when slicing through Bambuddy, not one printer. Multi-colour plates masked it — their tool-change macros come from a different setting and are emitted per filament change — so a single-filament plate is the reliable way to tell.
From 1.2.6 Bambuddy refuses such a slice outright rather than saving it, with an error naming the printer preset and pointing at the sidecar. If you see that message, the update above is the fix.
A PETG (or ABS, or TPU) slice came out at PLA temperatures¶
The slice succeeds, the file looks normal, but the filament reads as PLA and the nozzle temperature is 200 °C regardless of the profile picked.
This happens when the sidecar's bundled profile tree does not contain the filament preset by the name it was picked under. Nothing rejects it: the slicer inherits nothing, falls back to its compiled-in defaults for every field, and returns a perfectly well-formed file. The giveaway inside the resulting G-code 3MF is filament_vendor: ["(Undefined)"] alongside an empty filament_ids.
From 1.2.6 Bambuddy spots this and writes a warning to the log naming the slot and the preset:
The slicer could not resolve the filament preset for slot 1 (Creality PETG DBA), so those
slots were sliced with its built-in defaults (PLA, 200 C) instead of the preset's own settings.
The file is kept rather than refused — it prints, it is just wrong — so check the temperatures before printing it. The fix is to update the sidecar image (see above) so its bundle carries the preset, or to pick a preset from the sidecar's own standard tier.
Profile resolver errors ("not compatible with printer")¶
The fork's profile resolver walks OrcaSlicer's inherits: chain to a root system profile and rewrites from: "User" → from: "system". If you exported your preset from a non-stock OrcaSlicer build, the chain may not resolve cleanly. Workaround: re-export the preset from a stock OrcaSlicer install, or open an issue with the upstream profile bundled.
The same wording also appears when a picked filament profile simply belongs to another printer — the message names the slot: "filament preset X (slot 1) is not compatible with printer Bambu Lab A1 0.4 nozzle". Profiles you saved for a specific printer carry it in their name (… @Bambu Lab H2D 0.4 nozzle, … @BBL H2D); the slice dialog groups those under Other printers so they aren't picked by accident. For slots your plate doesn't use, see Filament slots your plate doesn't use.
OrcaSlicer mid-2026 CLI breakage¶
OrcaSlicer 2.3.2 / 2.4.0-dev have known CLI bugs that block slicing many Bambu-authored 3MFs — see upstream SoftFever/OrcaSlicer#12426 (segfault on painted multi-extruder files) and #13386 (parameter-range strict-validation reject). Bambu Studio is recommended until the upstream fixes land — the bambu-studio-api service is a drop-in replacement with the same API surface. Switch via Settings → Workflow → Preferred Slicer.
For 3MF inputs that hit the CLI bugs anyway, Bambuddy automatically retries without --load-settings (using the file's embedded settings). The job still completes with used_embedded_settings: true flagged in the result.
Sidecar source¶
Both sidecar images are published to two registries:
- GHCR:
ghcr.io/maziggy/orca-slicer-apiandghcr.io/maziggy/bambu-studio-api - Docker Hub:
docker.io/maziggy/orca-slicer-apianddocker.io/maziggy/bambu-studio-api
Each stable Bambuddy release publishes two tags per image: :latest (current stable) and :bambuddy-X.Y.Z (immutable pin matching the Bambuddy version).
Both images are built from the maziggy/orca-slicer-api fork, branch bambuddy/profile-resolver. The fork patches:
inherits:chain resolver — walks user-cloned profiles to a root system profilefrom: "User"→"system"rewrite — OrcaSlicer CLI's compatibility check rejects user-marked profiles#clone-prefix strip — OrcaSlicer GUI prefixes user clones with#, which the CLI doesn't accept- Sentinel-value strip — removes
-1and""placeholders that the CLI rejects as "not in range"
These patches are empirically required to slice real GUI exports without segfaulting the CLI. Once they land upstream, the Compose file can be flipped back to ghcr.io/afkfelix/orca-slicer-api.
Building from source (advanced)¶
If you want to roll your own sidecar image — tweaking the resolver, testing a newer slicer AppImage, etc. — clone the fork and use Docker's git build context:
# In docker-compose.yml, replace the `image:` line with:
build:
context: https://github.com/maziggy/orca-slicer-api.git#bambuddy/profile-resolver
dockerfile: Dockerfile # or Dockerfile.bambu-studio
This requires git in your Docker BuildKit worker. QNAP Container Station and Synology DSM do not ship git by default — on those platforms, stick with the pre-built images.
Updating¶
If you run OrcaSlicer only (the default):
If you run the Bambu Studio sidecar (with or without OrcaSlicer alongside it), the profile flag belongs on both commands:
docker compose pull on its own never updates the Bambu Studio sidecar
bambu-studio-api is declared with profiles: [bambu], and Compose skips profile-gated services unless the profile is enabled or the service is named — without a word of warning. The pull reports success, restart: unless-stopped keeps the old container running, and you stay on the old image however many times you repeat it.
To update one sidecar only, name it instead: docker compose pull bambu-studio-api && docker compose up -d bambu-studio-api. Naming a service enables its profile implicitly.
Compose pulls the current :latest (or whatever SIDECAR_TAG you've pinned to in .env) and recreates the containers.
To roll back to the sidecar that shipped with a previous Bambuddy release, set SIDECAR_TAG=bambuddy-X.Y.Z in .env and re-run the two commands above.
To confirm which image is actually running, ask Docker rather than the support package:
The support package (Bambuddy 0.2.5+) has integrations.slicer_api.bambu_studio_version / orcaslicer_version, but these carry the slicer CLI version as the sidecar reports it, and the Bambu Studio sidecar usually reports nothing at all — an empty value there says nothing about the image's age.
Orphan containers after a rebuild¶
If docker compose up -d errors with
Error response from daemon: Conflict. The container name "/bambu-studio-api" is already
in use by container "..."
the existing container was created from an older slicer-api/docker-compose.yml whose image tags didn't carry the bambuddy- prefix (the rename happened when the bundle-import branch landed). Compose tracks containers by project labels — the old containers' labels don't match the current project, so docker compose down doesn't see them, but container_name: still pins the name.
One-time cleanup:
Optionally clear the now-unreferenced old images:
Only required once — the next up -d cycle creates containers under the correct project labels and docker compose down works normally from then on.
