Slicer Pipelines¶
Save a printer + process + filament + bed-type combination once, then apply the whole bundle with a single click on the next file. Each pipeline can target a specific printer or a printer class, run multiple copies, and fan copies out across multiple printers in parallel.
What a Pipeline Is¶
A pipeline is a named, reusable bundle that captures everything the Slice dialog needs to slice a file the same way every time:
- Printer profile (e.g.
Bambu Lab H2D 0.4 nozzle) - Process profile (e.g.
0.20mm Standard @BBL H2D) - One filament profile per AMS slot (resolved against your imported / cloud / standard preset library)
- Bed type (Cool Plate / Engineering Plate / Textured PEI / …)
- Target — either a specific printer, or a printer class (e.g. any X1C)
- Copies — slice the file once, dispatch the resulting
.gcode.3mfas N independent print queue items - Fanout strategy — when N > 1, how to distribute the copies across printers in the class
Pipelines live under Settings → Workflow → Slicer Pipelines for editing, and on the Print Queue → Pipelines tab for the live runs dashboard.
Saving a Pipeline¶
The fastest way to make one is to open the Slice dialog for any file:
- Pick your printer, process, filaments, and bed type as normal
- Click Save as pipeline at the bottom of the dialog
- Give the pipeline a name (e.g.
H2D — PETG-CF 0.4mm) - Confirm
Your new pipeline appears under Settings → Workflow → Slicer Pipelines and is immediately available on every file's Run with pipeline menu.
You can also create one from scratch in Settings, but starting from a real Slice dialog avoids re-picking the same triplet manually.
Running a Pipeline¶
Pipelines can be applied to any sliceable file:
- File Manager — the row's overflow menu (⋮) and the per-row action button both expose Run with pipeline → \<name>
- Archives — the row menu offers Reprint with pipeline → \<name> for any archive whose source 3MF is still in the library
Clicking a pipeline kicks off a pipeline run that:
- Slices the file via the slicer sidecar using the pipeline's printer + process + filament + bed type
- Creates one or more print queue items (one per copy) with the resulting
.gcode.3mf - Hands dispatch to the existing queue scheduler
Each run shows up live on the Print Queue → Pipelines dashboard.
Targeting¶
Pipelines can be pinned in one of two ways:
Specific printer¶
The run goes to that printer's queue. Useful when one printer is the only one wearing the right nozzle / bed / colour combination for this recipe.
Printer class¶
The run goes to any printer of this class (e.g. any H2D). This lets one pipeline serve a fleet of identical machines — the queue scheduler picks the first available printer of the class. With copies > 1 the run becomes a fanout (see below).
The Target picker on every pipeline card is grouped by Specific printer and Printer class; only printers and classes that at least one saved pipeline points at appear in the filter dropdowns so the menu stays short on installs with many printers.
Multi-Copy & Fanout¶
A pipeline run can produce up to N copies of the sliced file as independent queue items. When targeting is set to printer class, those copies are distributed across the available printers in the class according to the chosen fanout strategy:
| Strategy | Behaviour |
| Spread | Distribute copies as evenly as possible across all idle printers in the class — finishes the batch fastest. |
| Single printer | Send every copy to the same printer (the first idle one matching the class). Best when colour-change overhead between copies is what dominates wall-clock. |
| First N | Send one copy to each of the first N idle printers, in class order. |
The slice runs once per pipeline run — N copies share the same .gcode.3mf — so a 5-copy fanout doesn't pay the slice cost 5×.
The Runs Dashboard¶
Print Queue → Pipelines lists every pipeline run across every pipeline. Each row shows:
- Run number, pipeline name, status badge (queued / slicing / dispatching / in-progress / completed / partial-failure / failed / cancelled), and the target chip (
Any X1Cor the specific printer name) - Source filename
- Created-at timestamp, total copies, and a
completed/totalroll-up — failed copies are flagged in red - Per-copy detail when expanded (each copy's status, assigned printer, and per-copy error message if any)
Filters¶
Three filter dropdowns at the top of the dashboard:
- Pipeline — narrow to one specific pipeline's runs
- Status — narrow to runs in a single state (e.g. partial failure)
- Target — narrow to runs of a specific printer or printer class
Each dropdown shows only entries that actually exist in your data, so empty options never appear.
In-flight actions¶
- Cancel — visible on
queued/slicing/dispatching/in_progressruns; cancels every still-pending copy. A run's queue jobs belong to whoever started it, so cancelling someone else's run takes the right to change everyone's queue jobs - Retry failed — visible on
partial_failure/failedruns; re-runs only the copies that didn't complete (the successful copies are not re-printed)
Clearing terminal runs¶
The Clear log button (top-right of the filter row) opens a confirmation modal and then deletes every terminal run (completed, failed, cancelled, partial_failure): your own, or everyone's if you may change everyone's queue jobs. In-flight runs are never deleted — clearing during an active batch is safe.
A run started by someone else shows its source file and its queue jobs only if you can see them on the File Manager, Archives and Queue pages.
Permissions¶
Three distinct permissions gate the feature so authoring a recipe is a different trust dimension than spending filament with it:
| Permission | What it allows |
pipelines:read | View saved pipelines + view the runs dashboard |
pipelines:write | Create, edit, delete pipelines; clear the runs log |
pipelines:run | Kick off a pipeline run, cancel a running run, retry failed copies |
Default group membership:
| Group | pipelines:read | pipelines:write | pipelines:run |
| Administrators | |||
| Operators | |||
| Viewers | — | — |
API keys can read and run pipelines, but not author them:
pipelines:readneeds the key's Read Status toggle.pipelines:runneeds Manage Queue and Manage Library together, because a run slices into the library and then queues prints — two things a key is trusted with separately. A key holding only one gets a 403 naming the other.pipelines:writeis admin-only and rejects every API key. A key can run the recipe; it cannot rewrite it, or clear the runs log.- A pipeline whose presets come from Bambu Cloud or Orca Cloud additionally needs Allow Cloud Access on the key, since resolving those reads the cloud token stored on the key owner's account. Local and standard presets need nothing extra.
See API Keys for the toggle list.
Upgrading from an older version
On installs seeded before pipelines existed, the upgrade gives the Administrators and Operators groups all three permissions, and any other group that can read the library or settings gets pipelines:read. That happens once: a permission you later remove from a group stays removed. Grant pipelines:write and pipelines:run through Settings → Users → Groups if a custom role needs them.
Where Things Live¶
| Path | Purpose |
| Settings → Workflow → Slicer Pipelines | Manage the pipeline catalogue (create / edit / delete / inspect) |
| Print Queue → Pipelines | Live runs dashboard (filter / expand / cancel / retry / clear) |
| File Manager → ⋮ → Run with pipeline | Apply a pipeline to a library file |
| Archives → ⋮ → Reprint with pipeline | Re-run a pipeline against a previously-archived 3MF |
| Slice dialog → Save as pipeline | Capture the current Slice modal selection as a new pipeline |
