System Info
View system information and database statistics.
The System Info page shows:
  • Database statistics - Archive counts, sizes
  • Resource usage - Memory, storage
  • Application info - Version, uptime
Database Statistics
Archive Statistics
Metric Description
Total Archives Number of archived prints
Total Size Database file size
3MF Files Number of stored 3MF files
Thumbnails Number of thumbnail images
Photos Number of attached photos
Metric Description
Successful Prints Completed prints
Failed Prints Print failures
Total Print Time Cumulative hours
Total Filament Cumulative kg
Database Health
Check Status
Integrity Database file intact
FTS Index Full-text search working
Connections Active database connections
Resource Usage
Memory
Metric Value
RAM Used Current usage
RAM Available Free memory
Process Memory Bambuddy process
Storage
Metric Value
Database Size SQLite file size
Archive Folder 3MF and thumbnail storage
Log Files Log directory size
Total Used All Bambuddy data
Disk Space
Location Free Space
Data Directory Available storage
Archive Directory Available storage
Application Info
Version
Info Value
Version Current Bambuddy version
Python Python version
Database SQLite version
Runtime
Info Value
Uptime Time since start
Started Start timestamp
Restarts Number of restarts
Environment
Info Value
OS Operating system
Architecture CPU architecture
Docker Running in Docker?
Maintenance Actions
Rebuild FTS Index
If search isn't working correctly:
  1. Click Rebuild Search Index
  2. Wait for completion
  3. Search should work now
Clear Cache
Remove temporary files:
  1. Click Clear Cache
  2. Confirm action
  3. Cache is cleared
Vacuum Database
Optimize database size:
  1. Click Vacuum Database
  3. May reduce file size
When to Vacuum
Vacuum after deleting many archives to reclaim disk space.
Debug Information
Log Files
Access application logs:
Log Content
Application General operations
MQTT Printer communication
Database Database operations
Log Level
Configure logging detail:
Level Detail
ERROR Only errors
WARNING Errors + warnings
INFO Normal operations
DEBUG Everything (verbose)
Log Viewer
View and filter application logs in real-time directly from the System Information page.
Opening the Log Viewer
  1. Go to System Information page
  2. Find Support & Troubleshooting section
  3. Click on Application Logs to expand the viewer
Controls
Button Action
Start Begin live streaming (auto-refresh every 2 seconds)
Stop Pause live streaming
Clear Clear the log file
Refresh Manual one-time refresh
Filtering Options
Filter Description
Level Filter by log level: All, DEBUG, INFO, WARNING, ERROR
Search Text search across messages and logger names
Auto-scroll Automatically scroll to newest entries
Log Entry Details
Each log entry shows:
  • Timestamp - Time the log was written
  • Level - Log severity (color-coded)
  • Logger - Component that generated the log
  • Message - Log content
Click on entries with multi-line content (like stack traces) to expand them.
Log Levels
Level Color Description
DEBUG Gray Detailed debugging information
INFO Blue Normal operational messages
WARNING Yellow Warning conditions
ERROR Red Error conditions
Debug Level Logs
DEBUG level logs are only captured when debug logging is enabled. Use the debug toggle above the log viewer to enable detailed logging.
Support Bundle
Generate a support bundle for issue reporting. The bundle contains debug logs and system information to help diagnose problems.
Enable Debug Logging
Before generating a support bundle:
  3. Click Enable to turn on debug logging
  4. A banner appears across all pages showing debug mode is active with a live timer
  5. Reproduce the issue you want to report
  6. Click Download to get the support bundle
What's Collected
Data Description
App version Current Bambuddy version
OS info Platform, architecture, Python version
Database stats Archive/printer/filament counts (numbers only)
Printer diagnostics Model, firmware version, connectivity status, AMS unit/tray counts, WiFi signal, HMS error count (no names, IPs, or serials)
Integration status Spoolman reachability, MQTT relay connection, Home Assistant enabled, notification provider types
Network interfaces Interface names and subnets only (e.g., 192.168.1.0/24) — no host IPs
Python packages Versions of key dependencies (FastAPI, Pydantic, etc.)
Database health SQLite journal mode, integrity check, DB/WAL file sizes
Docker environment Container memory limit, network mode hint (only when running in Docker)
WebSocket connections Number of active browser connections
Log file Log file size
Settings Non-sensitive settings (themes, formats)
Debug logs Sanitized application logs
What's NOT Collected
Data Reason
Printer names/IPs/serials Privacy
Access codes/passwords Security
Email addresses Filtered from settings and logs
API keys/tokens Security
Webhook URLs May contain sensitive info
Your hostname/username Privacy
Privacy First
IP addresses in logs are replaced with [IP] and email addresses with [EMAIL]. Paths are sanitized to hide usernames.
Using the Bundle
  1. Download the ZIP file
  2. Attach it to your GitHub issue
  3. Describe the problem you encountered
  4. Remember to disable debug logging when done
Disable Debug Logging
Debug logging increases log verbosity and file size. Remember to disable it after collecting the bundle.
API Endpoint
Get system info via API:
GET /api/v1/system/info
Response includes:
  "version": "0.1.5b6",
  "uptime": 86400,
  "database": {
    "archives": 1234,
    "size_mb": 45.6
  "resources": {
    "memory_mb": 256,
    "disk_free_gb": 100
Regular Checks
Check system info periodically to monitor storage and performance.
Before Backups
Review database size before backing up to plan storage.
Check uptime and logs when investigating issues.
Clean Up
Use vacuum and cache clear to maintain performance.
