System Info¶
View system information and database statistics.
The System Info page shows:
- Database statistics - Archive counts, sizes
- Resource usage - Memory, storage
- Application info - Version, uptime
Database Statistics¶
Archive Statistics¶
| Metric | Description |
| Total Archives | Number of archived prints |
| Total Size | Database file size |
| 3MF Files | Number of stored 3MF files |
| Thumbnails | Number of thumbnail images |
| Photos | Number of attached photos |
Print Statistics¶
| Successful Prints | Completed prints |
| Failed Prints | Print failures |
| Total Print Time | Cumulative hours |
| Total Filament | Cumulative kg |
Database Health¶
| Check | Status |
| Integrity | Database file intact |
| FTS Index | Full-text search working |
| Connections | Active database connections |
Resource Usage¶
Memory¶
| Metric | Value |
| RAM Used | Current usage |
| RAM Available | Free memory |
| Process Memory | Bambuddy process |
Storage¶
| Metric | Value |
| Database Size | SQLite file size |
| Archive Folder | 3MF and thumbnail storage |
| Log Files | Log directory size |
| Total Used | All Bambuddy data |
Disk Space¶
| Location | Free Space |
| Data Directory | Available storage |
| Archive Directory | Available storage |
Application Info¶
Version¶
| Info | Value |
| Version | Current Bambuddy version |
| Python | Python version |
| Database | SQLite version |
Runtime¶
| Info | Value |
| Uptime | Time since start |
| Started | Start timestamp |
| Restarts | Number of restarts |
Environment¶
| Info | Value |
| OS | Operating system |
| Architecture | CPU architecture |
| Docker | Running in Docker? |
Application Updates¶
Bambuddy can check for and install updates directly from the Settings page.
Checking for Updates¶
- Go to Settings > General
- Updates are checked automatically, or click Check for Updates
- If a new version is available, the update details are shown
Beta Updates¶
To receive pre-release versions:
- Enable Include beta updates
- Beta versions will appear in update checks
Installing Updates¶
When an update is available:
- Review the release notes
- Click Update to begin
- Progress is shown during download and installation
- Bambuddy restarts automatically after the update
Docker Users
For Docker installations, updates are applied by pulling the latest image. The in-app updater is for bare-metal/systemd installations.
Maintenance Actions¶
Rebuild FTS Index¶
If search isn't working correctly:
- Click Rebuild Search Index
- Wait for completion
- Search should work now
Clear Cache¶
Remove temporary files:
- Click Clear Cache
- Confirm action
- Cache is cleared
Vacuum Database¶
Optimize database size:
- Click Vacuum Database
- May reduce file size
When to Vacuum
Vacuum after deleting many archives to reclaim disk space.
Connection Diagnostic¶
The Connection Diagnostic section lists every configured printer with a Run diagnostic button. It checks why a printer won't connect or won't print:
- TCP reachability of the MQTT (8883), FTPS (990), and RTSPS (322) ports
- LAN Developer Mode
- Container network mode (host vs bridge), for Docker, Podman, Kubernetes and LXC/LXD alike. Where the mode genuinely cannot be read the check says so instead of guessing.
- Whether the printer and the Bambuddy host are on the same subnet, read at the real prefix of the interface that routes to the printer — not assumed to be a
/24 - Printer credentials (access code / serial number)
- Store sent files on external storage — verifies the printer-side variant of install step 4. Reads the toggle's state from the MQTT status push (
home_flagbit 11), so the check is instant. Catches the newer firmware variant (P2S 01.02 / Bambu Studio 2.6+) where the setting moved to the printer. The older slicer-side variant of the setting is invisible to the printer, so the check will pass even when the option is off in the slicer — when in doubt, verify install step 4 manually.
Each check reports pass, fail, warning, or skipped, with a plain-language fix. The same diagnostic is also available from the printer card (when a printer is offline) and the Add Printer dialog.
Debug Information¶
Log Files¶
Access application logs:
| Log | Content |
| Application | General operations |
| MQTT | Printer communication |
| Database | Database operations |
Log Level¶
Configure logging detail:
| Level | Detail |
| ERROR | Only errors |
| WARNING | Errors + warnings |
| INFO | Normal operations |
| DEBUG | Everything (verbose) |
Log Viewer¶
View and filter application logs in real-time directly from the System Information page.
Opening the Log Viewer¶
- Go to System Information page
- Find Support & Troubleshooting section
- Click on Application Logs to expand the viewer
Controls¶
| Button | Action |
| Start | Begin live streaming (auto-refresh every 2 seconds) |
| Stop | Pause live streaming |
| Clear | Clear the log file |
| Refresh | Manual one-time refresh |
Filtering Options¶
| Filter | Description |
| Level | Filter by log level: All, DEBUG, INFO, WARNING, ERROR |
| Search | Text search across messages and logger names |
| Auto-scroll | Automatically scroll to newest entries |
Log Entry Details¶
Each log entry shows:
- Timestamp - Time the log was written
- Level - Log severity (color-coded)
- Logger - Component that generated the log
- Message - Log content
Click on entries with multi-line content (like stack traces) to expand them.
Log Levels¶
| Level | Color | Description |
| DEBUG | Gray | Detailed debugging information |
| INFO | Blue | Normal operational messages |
| WARNING | Yellow | Warning conditions |
| ERROR | Red | Error conditions |
Debug Level Logs
DEBUG level logs are only captured when debug logging is enabled. Use the debug toggle above the log viewer to enable detailed logging.
Support Bundle¶
Generate a support bundle for issue reporting. The bundle contains debug logs and system information to help diagnose problems.
The Support & Troubleshooting section (debug logging, support bundle and the log viewer) is shown to users with the settings:update permission. The logs cover every printer, so viewers don't get them.
Enable Debug Logging¶
Before generating a support bundle:
- Click Enable to turn on debug logging
- A banner appears across all pages showing debug mode is active with a live timer
- Reproduce the issue you want to report
- Click Download to get the support bundle
What's Collected¶
| Data | Description |
| App version | Current Bambuddy version |
| OS info | Platform, architecture, Python version |
| Database stats | Archive/printer/filament counts (numbers only) |
| Printer diagnostics | Model, firmware version, connectivity status, AMS unit/tray counts, WiFi signal, HMS error count (no names or serials) |
| Integration status | Spoolman reachability, MQTT relay connection, Home Assistant enabled, notification provider types |
| Network interfaces | Interface names and subnets only (e.g., 192.168.1.0/24) — no host IPs |
| Python packages | Versions of key dependencies (FastAPI, Pydantic, etc.) |
| Database health | SQLite journal mode, integrity check, DB/WAL file sizes |
| Docker environment | Container memory limit, network mode hint (only when running in Docker) |
| Process resources | Bambuddy's resident and virtual memory, thread count, child processes by executable name only, open file and socket counts, uptime, and a census of live objects by type. Included so reports of memory growing over time can be diagnosed from the bundle. The object census is skipped when the process is already above 2 GB — walking the heap costs most on a process that is short of memory. |
| WebSocket connections | Number of active browser connections |
| Log file | Log file size |
| Settings | Non-sensitive settings (themes, formats) |
| Debug logs | Sanitized application logs |
What's NOT Collected¶
| Data | Reason |
| Printer names/serials | Privacy |
| Access codes/passwords | Security |
| IP addresses | Privacy |
| Email addresses | Filtered from settings and logs |
| API keys/tokens | Security |
| Webhook URLs | May contain sensitive info |
| Your hostname/username | Privacy |
| Child process command lines | An ffmpeg command line carries the camera URL, and with it the camera password — only the executable name is recorded |
Privacy First
Email addresses in logs are replaced with [EMAIL], printer names with [PRINTER], serial numbers with [SERIAL], and IP addresses with [IP]. Paths are sanitized to hide usernames.
Using the Bundle¶
- Download the ZIP file
- Attach it to your GitHub issue
- Describe the problem you encountered
- Remember to disable debug logging when done
Disable Debug Logging
Debug logging increases log verbosity and file size. Remember to disable it after collecting the bundle.
API Endpoint¶
Get system info via API:
Response (trimmed):
"app": {"version": "1.2.6b1"},
"database": {"engine": "SQLite", "archives": 1234},
"printers": {"total": 3, "connected": 2},
"storage": {"database_size_bytes": 47815065, "disk_free_bytes": 107374182400},
"system": {"uptime_seconds": 86400},
"memory": {"used_bytes": 268435456, "percent_used": 41.5},
"cpu": {"count": 4, "percent": 12.0}
Sections: app, database, printers, storage, system, memory, cpu. Sizes are in bytes, each with a _formatted twin ("45.6 MB"). Needs system:read.
Regular Checks
Check system info periodically to monitor storage and performance.
Before Backups
Review database size before backing up to plan storage.
Check uptime and logs when investigating issues.
Clean Up
Use vacuum and cache clear to maintain performance.
