Virtual Printer¶
Send prints to Bambuddy directly from Bambu Studio or OrcaSlicer — even when your real printer is busy, offline, or doesn't exist yet.
Print Archiving
Send prints to Bambuddy for archiving without starting them.
Queue Building
Build up a print queue before your printer is available.
Print Farm Prep
Prepare jobs to distribute across multiple printers.
Remote Slicing
Slice on one computer, send to Bambuddy running elsewhere.
Remote Printing
Print from anywhere via Proxy Mode.
The Virtual Printer feature allows Bambuddy to emulate one or more Bambu Lab printers on your network. This enables you to send prints directly from Bambu Studio or OrcaSlicer to Bambuddy, even without a physical printer connected.
You can create multiple virtual printers, each with its own dedicated IP address, mode, printer model, and access code. Each virtual printer runs completely independent services (FTP, MQTT, SSDP, Bind).
When enabled, each virtual printer:
- Can be discovered automatically via SSDP (same LAN) or added manually by IP (VPN, remote, Docker bridge)
- Accepts print jobs over secure TLS connections (MQTT + FTP)
- Archives prints directly, queues them for review, or adds them to the print queue
- Works with the same workflow as sending to a real Bambu Lab printer
- Runs on its own dedicated bind IP with independent services
Modes¶
The virtual printer supports four modes:
| Mode | Description |
| Immediate | Files are archived automatically when received |
| Review | Files go to pending uploads for manual review before archiving |
| Print Queue | Files are archived AND added to the print queue (unassigned). Two toggles: Auto-dispatch controls whether incoming prints start automatically (enabled by default) or require manual dispatch. Force color match (off by default — opt-in) tells the scheduler to refuse to dispatch onto a printer that does not have the exact filament type and color loaded. Without it, the queue uses model-only matching and may pick a printer with the wrong colour loaded. |
| Proxy | Forwards traffic directly to a real printer (remote printing) |
The first three are server modes — Bambuddy runs its own FTP/MQTT servers and receives files locally. Proxy mode is different — Bambuddy uses transparent TCP proxying to forward traffic to a real printer, with end-to-end TLS between the slicer and printer for most protocols.
Server modes with a target printer mirror its live state to the slicer
When you set a target printer on an Immediate / Review / Print Queue VP, the slicer sees the target's live AMS slots, FTS / dual-extruder routing, k-profiles, nozzle / temperature state, and the camera stream — same view a direct slicer connection would get, but with Bambuddy's queue / archive / review workflow on the receiving end. AMS load / dry / calibration commands from the slicer pass through to the real printer too. See Live target-printer mirror for setup and the access-code requirement for camera. If you don't set a target, the VP behaves as a pure file receiver with no live data — which is fine if you only need slice-and-archive.
Required Ports¶
You don't usually need to configure these
The installer and UI handle port setup automatically. This table is reference for advanced setups, firewall rules, or Docker networking — safe to skim on a first read.
Each virtual printer uses these ports on its dedicated bind IP:
| Service | Port | Protocol | Purpose |
| Bind | 3000, 3002 | TCP | Slicer bind/detect handshake (required for all modes) |
| SSDP | 2021 | UDP | Printer discovery (same LAN only, not needed for VPN/remote) |
| MQTT | 8883 | TCP/TLS | Printer communication |
| File Transfer | 6000 | TCP/TLS | Verify job & file upload tunnel (proxy mode) |
| RTSP Camera | 322 | TCP/TLS | Camera streaming for X1/H2/P2 series (proxy mode, and non-proxy modes when a target printer is configured — required for the slicer's live camera view to work through the VP) |
| FTPS | 990 | TCP/TLS | File transfer control |
| FTP Data | 50000-50100 | TCP | File transfer passive data |
Dual Bind Ports
Different versions of BambuStudio and OrcaSlicer use different ports for the bind/detect handshake. Bambuddy listens on both 3000 and 3002 to support all slicer versions.
Port 990
The FTP server binds directly to port 990 (the standard FTPS port). This requires CAP_NET_BIND_SERVICE capability for the process, or running as root. The systemd service file and Docker image already include this capability.
Certificate Installation¶
Required Step
The virtual printer uses TLS encryption with a self-signed CA certificate. On macOS and Windows, Bambu Studio and OrcaSlicer do not use the system certificate store — you must add the certificate directly to the slicer's printer.cer file. On Linux the right approach depends on how you installed the slicer: native .deb / .rpm packages can use the system CA store, but AppImage builds typically need the bundled printer.cer edited directly. See the Linux tab for both paths.
Step 1: Locate the CA Certificate¶
The Bambuddy CA certificate is at:
- Native install:
virtual_printer/certs/bbl_ca.crt - Docker: Extract with
docker cp bambuddy:/app/data/virtual_printer/certs/bbl_ca.crt ./bambuddy-ca.crt
Certificate Generation
The certificate is only generated when you first enable the virtual printer in the UI. If the file doesn't exist, enable the virtual printer first.
Step 2: Append the Bambuddy CA Certificate to Slicer¶
The slicer's printer.cer file contains PEM certificates. You need to append the Bambuddy CA certificate to this file.
The slicer's printer connection certificates are completely separate from the system keyring.
Open printer.cer in a text editor and:
- Go to the end of the file
- Paste the entire contents of
bambuddy-ca.crtafter the last-----END CERTIFICATE----- - Save the file
- Fully restart the slicer (Cmd+Q on macOS, not just close the window)
Keep Original Certificates
Appending (rather than replacing) preserves your ability to connect to physical Bambu Lab printers while also enabling the virtual printer.
Certificate file locations:
Certificate file location depends on installation options
When changing the installation path or method, the files location may differ from the defaults listed below, search for a file named printer.cer located in the resources/cert/ subfolders.
- Bambu Studio:
/Applications/BambuStudio.app/Contents/Resources/cert/printer.cer - OrcaSlicer:
/Applications/OrcaSlicer.app/Contents/Resources/cert/printer.cer
- Bambu Studio:
C:\Program Files\Bambu Studio\resources\cert\printer.cer - OrcaSlicer:
C:\Program Files\OrcaSlicer\resources\cert\printer.cer
The right approach depends on how you installed Bambu Studio / OrcaSlicer.
AppImage — extract and edit printer.cer
The system CA store path is unreliable for AppImage builds even when tls_cert_store_accepted: yes is set in BambuStudio.conf (#1140) — the AppImage ships its own networking stack and doesn't always honour the system bundle. Extract the AppImage, edit the bundled printer.cer, then run from the extracted tree:
./Bambu_Studio_linux_*.AppImage --appimage-extract
# edit squashfs-root/usr/share/Bambu Studio/resources/cert/printer.cer
./squashfs-root/AppRun
Append the contents of bbl_ca.crt after the last -----END CERTIFICATE----- in printer.cer, save, and run ./squashfs-root/AppRun. You need to repeat this each time you update the AppImage to a new version (the old extracted tree won't pick up new slicer features).
Native package install (.deb / .rpm) — system CA store
Native packages link against the system OpenSSL and pick up the system CA bundle when tls_cert_store_accepted: yes is set in ~/.config/BambuStudio/BambuStudio.conf (the default after first launch).
Debian / Ubuntu / Mint / Raspberry Pi OS:
sudo cp bbl_ca.crt /usr/local/share/ca-certificates/bambuddy-ca.crt # extension MUST be .crt
sudo update-ca-certificates
Fedora / RHEL / openSUSE:
Arch:
Then fully quit and relaunch the slicer.
Common pitfall
Dropping the .crt file directly into /etc/ssl/certs/ and running update-ca-certificates is a no-op — the tool only picks up files placed under /usr/local/share/ca-certificates/ with a .crt extension.
If the system CA store doesn't work for your install (Flatpak sandboxes, statically-linked builds, or AppImage despite the conf setting), fall back to the direct-edit path:
- Bambu Studio (
.deb/.rpm):/usr/share/Bambu Studio/resources/cert/printer.cer - OrcaSlicer (
.deb/.rpm):/usr/share/OrcaSlicer/resources/cert/printer.cer
Editing those requires sudo and gets reverted on every package update.
These are owned by root; edit with sudo.
When to Update the Certificate
You must update the printer.cer file whenever:
- First-time setup — append the Bambuddy CA certificate
- New Bambuddy installation — each install generates a unique CA
- Switching Bambuddy hosts — each host has its own CA (unless you share the CA)
- After slicer updates — updates may restore the original certificate file, requiring you to append again
Certificate Persistence¶
The CA certificate is generated once and persists across Bambuddy restarts. If you switch between Docker and native installations, share the certificate directory to avoid regenerating:
Multiple Bambuddy Hosts¶
Each Bambuddy installation generates its own unique CA certificate.
One Bambuddy CA at a Time
When switching between Bambuddy hosts with different CAs, remove the old Bambuddy CA and append the new one. Having multiple Bambuddy CAs may cause confusion about which host to connect to.
Option 1: Share the CA (Recommended)
Copy the certs/ directory from one host to all others:
# Copy certs from host1 to host2
scp -r host1:/path/to/virtual_printer/certs/ host2:/path/to/virtual_printer/
Then restart Bambuddy on host2. All hosts will use the same CA, so one certificate in the slicer works for all.
Option 2: Update Certificate When Switching Hosts
Each time you switch to a different Bambuddy host:
- Extract the CA from the new host
- Open the slicer's
printer.cerfile - Remove the old Bambuddy CA (if present) and append the new one
Tailscale Integration (Optional)¶
Per-VP Tailscale nodes
Tailscale integration is off by default. When you flip the Tailscale integration toggle on a virtual printer card, Bambuddy registers that VP as its own device in your tailnet — with its own 100.x.x.x IP and MagicDNS hostname (e.g. bambuddy-h2d-1.tailXXXX.ts.net). Each VP is independent: VP1 and VP2 each get their own Tailscale identity, so you can paste different IPs into the slicer for different printers, all reachable from anywhere on your tailnet.
What this gives you¶
Secure remote access, per VP: every Tailscale-exposed VP becomes reachable from any tailnet device (laptop at work, phone on LTE, another site) over a private, end-to-end WireGuard-encrypted tunnel — without port forwarding, DDNS, reverse proxies, or exposing anything to the public internet. The slicer connects to the VP's 100.x.x.x exactly like it would a real printer on the LAN.
Slicer-side caveat — CA import is still required
Both Bambu Studio and OrcaSlicer validate printer TLS only against their bundled BBL CA store, not the system trust store. So even though Tailscale would happily issue Let's Encrypt certs, the slicer would reject them anyway. You still need to import Bambuddy's self-signed CA into your slicer, same as a LAN-mode install. Tailscale's role is secure network reach + per-VP IPs — not cert-import elimination.
How it works¶
A small Go sidecar (bambuddy-tsd) runs alongside Bambuddy and embeds Tailscale's tsnet library. For every VP with the Tailscale toggle on, the sidecar:
- Registers a node in your tailnet using the auth key from Settings → Virtual Printer → Tailscale auth key (one-time setup; reused across VPs).
- Receives the assigned
100.x.x.xIP andbambuddy-<vp-name>.<tailnet>.ts.nethostname. - Forwards Tailscale-side traffic on the standard Bambu protocol ports (8883 MQTT, 990 FTPS, 322 RTSPS, 6000 file transfer, 2024–2026, 50000–50100) to a per-VP loopback target inside Bambuddy.
The sidecar is shipped inside the Docker image and as a separate binary in sidecar/tsd/bin/ for native installs. No host tailscaled, no --operator setup, no TUN device wrangling — userspace networking via tsnet handles all of it.
Setup — one-time installation auth key¶
- Generate a reusable auth key at login.tailscale.com/admin/settings/keys. "Reusable" matters — Bambuddy uses one key to register every VP node. Tag the key as you see fit (e.g.
tag:bambuddy). - In Bambuddy, go to Settings → Virtual Printer → Tailscale auth key, paste the key, click Save. The value is encrypted at rest using the same Fernet key as TOTP/OIDC secrets (
MFA_ENCRYPTION_KEY).
That's it. The key is reused for every Tailscale-exposed VP across the lifetime of the installation. Re-issue and re-paste when it expires.
Setup — per VP¶
For each VP you want reachable over Tailscale:
- On the VP card, flip Tailscale integration on.
- Within a few seconds, the card shows the assigned
100.x.x.x (bambuddy-<name>-<id>.<tailnet>.ts.net)with a copy button. - Paste that
100.x.x.xinto your slicer's Add Printer dialog. - (One-time) import Bambuddy's CA into the slicer if you haven't already.
Building the sidecar — native installs only¶
Docker users get the sidecar baked into the image automatically; no action needed.
For native (non-Docker) installs:
Bambuddy resolves the binary in this order: the BAMBUDDY_TSD_PATH env var → the co-located <repo>/sidecar/tsd/bin/bambuddy-tsd → bambuddy-tsd on $PATH. Restart the Bambuddy service after building so it picks up the binary.
When Tailscale is the right choice¶
| You want… | Tailscale helps? |
| Print to Bambuddy from your laptop on another network | Yes — private tunnel + per-VP reach |
| Print from a friend's house or public wifi | Yes — no port forwarding needed |
| Distinguish multiple VPs in the tailnet admin | Yes — each VP is its own device with its own hostname |
| Eliminate the one-time CA import in Bambu Studio / Orca | No — slicer trusts only its bundled BBL CA |
| Avoid exposing Bambuddy on the public internet | Yes — tailnet is private (CGNAT) |
Toggle flips on but the VP card doesn't show a Tailscale IP¶
The sidecar couldn't register the node. Check the Bambuddy log for entries from virtual_printer.manager and virtual_printer.tsd_client. Usual causes:
- Auth key not set — Settings → Virtual Printer → Tailscale auth key is empty. The error log says: "No Tailscale auth key configured."
- Auth key expired or single-use — Tailscale rejected the registration. Generate a new reusable key and paste it again.
- Sidecar binary missing — log line: "bambuddy-tsd binary not found; per-VP Tailscale nodes are disabled." Build with
make -C sidecar/tsd build(native) or rebuild the Docker image.
How can I see the sidecar's view of the world?¶
bambuddy-tsd exposes its RPC over a Unix socket. From inside the same machine that's running Bambuddy:
# Locate the socket — defaults to <DATA_DIR>/tailscale/tsd.sock
ls /opt/bambuddy/data/tailscale/tsd.sock # native
docker exec bambuddy ls /app/data/tailscale/tsd.sock # Docker
# List currently registered nodes
curl --unix-socket /path/to/tsd.sock http://unix/nodes | jq
Node shows "offline" in the Tailscale admin console¶
The sidecar may have crashed or lost network. Check Bambuddy's log for "bambuddy-tsd exited unexpectedly" — that's the trigger. Restart Bambuddy; the sidecar comes back up and re-registers the nodes from the persisted state in <DATA_DIR>/tailscale/vp_<id>/. The same Tailscale identity is reused (auth key only needed on first registration).
Removing a VP doesn't remove it from the tailnet¶
Today, deleting a VP in Bambuddy tears down the running node but doesn't revoke the device entry in your tailnet admin. Remove it manually at login.tailscale.com/admin/machines. (A future release will tear down both.)
Slicer still shows "untrusted cert" / "failed to connect"¶
Expected if you skipped the CA import. Both Bambu Studio and OrcaSlicer trust only their bundled BBL CA store for printer-MQTT connections — system-trusted certs are rejected. Import Bambuddy's CA into the slicer as described above, then connect to the per-VP Tailscale IP.
FQDN copy button shows "Failed to copy"¶
navigator.clipboard is only available in secure contexts (HTTPS or localhost). On plain HTTP Bambuddy falls back to a legacy document.execCommand('copy') path. If both fail (very old browser, hostile extension), select the hostname manually and copy with Ctrl/Cmd-C.
Platform Setup¶
Choose your platform below for specific setup instructions.
Linux (Native Installation)¶
Port 990 is a privileged port. The process needs CAP_NET_BIND_SERVICE to bind to it.
For systemd services, add to the service file:
For manual runs, grant the capability to the Python binary:
sudo setcap cap_net_bind_service=+ep $(readlink -f $(which python3))
**Firewall rules (if using UFW):**
```bash
sudo ufw allow 3000/tcp # Bind/detect
sudo ufw allow 3002/tcp # Bind/detect
sudo ufw allow 2021/udp # SSDP
sudo ufw allow 8883/tcp # MQTT
sudo ufw allow 990/tcp # FTPS
sudo ufw allow 6000/tcp # File transfer tunnel
sudo ufw allow 322/tcp # RTSP camera (X1/H2/P2)
sudo ufw allow 2024:2026/tcp # Proprietary slicer ports (A1/P1S)
sudo ufw allow 50000:50100/tcp # FTP passive data
Firewall rules (if using firewalld):
sudo firewall-cmd --permanent --add-port=3000/tcp # Bind/detect
sudo firewall-cmd --permanent --add-port=3002/tcp # Bind/detect
sudo firewall-cmd --permanent --add-port=2021/udp # SSDP
sudo firewall-cmd --permanent --add-port=8883/tcp # MQTT
sudo firewall-cmd --permanent --add-port=990/tcp # FTPS
sudo firewall-cmd --permanent --add-port=6000/tcp # File transfer tunnel
sudo firewall-cmd --permanent --add-port=322/tcp # RTSP camera (X1/H2/P2)
sudo firewall-cmd --permanent --add-port=2024-2026/tcp # Proprietary slicer ports (A1/P1S)
sudo firewall-cmd --permanent --add-port=50000-50100/tcp # FTP passive data
sudo firewall-cmd --reload
Docker (Linux)¶
Docker requires host networking for SSDP discovery to work.
docker-compose.yml:
services:
bambuddy:
image: ghcr.io/maziggy/bambuddy:latest
container_name: bambuddy
network_mode: host # Required for SSDP discovery
cap_add:
- NET_BIND_SERVICE # Required for virtual printer proxy (port 990)
volumes:
- bambuddy_data:/app/data
- bambuddy_logs:/app/logs
environment:
- TZ=Europe/Berlin
restart: unless-stopped
volumes:
bambuddy_data:
bambuddy_logs:
No iptables redirect needed
The FTP server binds directly to port 990 inside the container. With network_mode: host, no port mapping or iptables redirect is required.
Docker (macOS / Windows)¶
Limited Support
Docker Desktop on macOS and Windows doesn't support host network mode. SSDP discovery will not work — you must add the printer manually by IP.
Use bridge networking with port mapping:
services:
bambuddy:
cap_add:
- NET_BIND_SERVICE
ports:
- "${PORT:-8000}:8000" # Web UI
- "3000:3000" # Bind/detect
- "3002:3002" # Bind/detect (alt port)
- "990:990" # FTPS
- "6000:6000" # File transfer tunnel
- "8883:8883" # MQTT
- "322:322" # RTSP camera (X1/H2/P2)
- "2024-2026:2024-2026" # Proprietary slicer ports (A1/P1S)
- "50000-50100:50000-50100" # FTP passive data
volumes:
environment:
- TZ=Europe/Berlin
# Required for FTP passive mode behind Docker NAT:
# Set to your Docker host's LAN IP
#- VIRTUAL_PRINTER_PASV_ADDRESS=192.168.1.100
volumes:
bambuddy_data:
bambuddy_logs:
PASV Address
When using bridge mode, FTP passive data connections need to know the host's real IP. Set VIRTUAL_PRINTER_PASV_ADDRESS to your Docker host's LAN IP address.
Unraid¶
- Set Network Type to
hostin container settings - No additional configuration needed — the FTP server binds directly to port 990
Synology NAS¶
- Use Host Network in Container Manager
TrueNAS SCALE¶
- Use Host Network when creating the app/container
Proxmox LXC¶
- No special configuration needed — the FTP server binds directly to port 990
- Ensure the LXC container runs Bambuddy as root or with
Configuration¶
Creating a Virtual Printer¶
- Complete the platform setup above first
- Go to Settings in Bambuddy
- Scroll to the Virtual Printer section
- Click Add Virtual Printer
- Set a Name for this virtual printer
- Choose your Mode: Immediate, Review, Print Queue, or Proxy
- Choose the Printer Model to emulate
- Set an Access Code (exactly 8 characters) — not needed for Proxy mode
- Enter a Bind IP — a dedicated IP address for this virtual printer
- Click Create, then toggle it to Enabled
You can create multiple virtual printers, each with its own mode, model, and bind IP. They appear as separate printers in your slicer.
Dedicated Bind IP¶
Each virtual printer requires its own dedicated IP address. This IP is used for all services (FTP, MQTT, SSDP, Bind) and must be unique across all enabled virtual printers.
For example, if you want to run 3 virtual printers:
| IP | |
| Bambuddy web UI | 192.168.1.100 (your main IP) |
| Virtual Printer 1 | 192.168.1.101 |
| Virtual Printer 2 | 192.168.1.102 |
| Virtual Printer 3 | 192.168.1.103 |
You add these extra IPs as interface aliases (secondary addresses) on your network adapter. The commands below are temporary — see the persistence section for each platform to keep them across reboots.
Adding Interface Aliases¶
Choose Unused IPs
Pick IP addresses that are outside your DHCP range or reserve them in your router to avoid conflicts. Check with ping 192.168.1.101 before adding.
Required package
The ip command comes from the iproute2 package, which is pre-installed on most distros. If missing: sudo apt install iproute2 (Debian/Ubuntu) or sudo dnf install iproute (Fedora/RHEL).
Find your interface name first:
Add secondary IPs:
sudo ip addr add 192.168.1.101/24 dev eth0
sudo ip addr add 192.168.1.102/24 dev eth0
sudo ip addr add 192.168.1.103/24 dev eth0
Verify:
Make persistent (choose your distro):
Install netplan if not already present:
Find your existing netplan config:
Edit the file (e.g., /etc/netplan/01-netcfg.yaml) and add the addresses block:
network:
version: 2
ethernets:
eth0:
dhcp4: true
addresses:
- 192.168.1.101/24
- 192.168.1.102/24
- 192.168.1.103/24
Apply:
Install ifupdown if not already present:
Add to /etc/network/interfaces:
auto eth0:1
iface eth0:1 inet static
address 192.168.1.101
netmask 255.255.255.0
auto eth0:2
iface eth0:2 inet static
address 192.168.1.102
auto eth0:3
iface eth0:3 inet static
address 192.168.1.103
Apply without reboot:
NetworkManager and nmcli are pre-installed on Fedora, RHEL, and most Arch desktop installs. If missing:
Add secondary IPs to your connection:
sudo nmcli con mod "Wired connection 1" +ipv4.addresses "192.168.1.101/24"
sudo nmcli con mod "Wired connection 1" +ipv4.addresses "192.168.1.102/24"
sudo nmcli con mod "Wired connection 1" +ipv4.addresses "192.168.1.103/24"
# Apply (brief reconnect)
sudo nmcli con up "Wired connection 1"
Find your connection name
Run nmcli con show to see your connection names. Common names: "Wired connection 1", "eno1", "enp0s3".
SSH into your Unraid server or use the terminal in the web UI:
Make persistent — add to /boot/config/go:
SSH into your NAS:
Make persistent — create a triggered task:
- Control Panel → Task Scheduler → Create → Triggered Task → User-defined script
- Event: Boot-up
- User: root
- Script:
You can add aliases through the web UI:
- Network → Interfaces → Edit your interface
- Add Aliases:
192.168.1.101/24,192.168.1.102/24, etc. - Click Save and Apply
These persist automatically.
Option A — Inside the LXC container (recommended):
Use the Linux instructions above. Install iproute2 if missing:
Then add IPs and make persistent with netplan or /etc/network/interfaces.
Option B — From the Proxmox host:
Add additional network devices to the LXC config (/etc/pve/lxc/100.conf):
net0: name=eth0,bridge=vmbr0,ip=192.168.1.100/24,gw=192.168.1.1
net1: name=eth1,bridge=vmbr0,ip=192.168.1.101/24
net2: name=eth2,bridge=vmbr0,ip=192.168.1.102/24
Or via CLI:
pct set 100 -net1 name=eth1,bridge=vmbr0,ip=192.168.1.101/24
pct set 100 -net2 name=eth2,bridge=vmbr0,ip=192.168.1.102/24
Restart the container after adding network devices.
Single Virtual Printer Only
Docker Desktop on macOS and Windows uses a VM — you cannot add host interface aliases into the container. Bridge mode limits you to one virtual printer per Docker host.
For multiple virtual printers, use Linux (native or VM with host networking).
Docker Host Mode
If you're running Bambuddy in Docker with network_mode: host, add the aliases on the Docker host (not inside the container). The container inherits all host IPs automatically.
Printer Model Selection¶
Choose which Bambu printer model the virtual printer should emulate:
| SSDP Code | Printer | Serial Prefix |
| 3DPrinter-X1-Carbon | X1C (default) | 00M |
| 3DPrinter-X1 | X1 | 00M |
| C13 | X1E | 03W |
| C11 | P1P | 01S |
| C12 | P1S | 01P |
| N7 | P2S | 22E |
| N2S | A1 | 039 |
| N1 | A1 Mini | 030 |
| O1D | H2D | 094 |
| O1C | H2C | 094 |
| O1S | H2S | 094 |
Model Change
Changing the printer model will automatically restart the virtual printer. You may need to re-add the printer in your slicer since the serial number changes.
Network Interface Override¶
Multi-NIC / Docker / VPN Users
If Bambuddy has multiple network interfaces (e.g., LAN + Tailscale, Docker with multiple bridges), the auto-detected IP may be wrong. Use Network Interface Override in Virtual Printer settings to select the correct interface.
This applies to all modes and affects:
- The IP address advertised via SSDP discovery
- The IP included in the TLS certificate (SAN)
Adding to Bambu Studio / OrcaSlicer¶
When Does Automatic Discovery Work?
SSDP discovery only works when the slicer and Bambuddy are on the same network segment (same LAN/subnet). You must add the printer manually by IP when:
- Connecting over a VPN (WireGuard, Tailscale, etc.)
- Using Docker bridge mode (macOS/Windows)
- Connecting over the internet via port forwarding
- The slicer is on a different subnet than Bambuddy
Automatic Discovery¶
- Ensure the virtual printer is enabled and running
- In Bambu Studio/OrcaSlicer, go to Device tab
- Click Refresh or wait for discovery
- The virtual printer "Bambuddy" should appear
- Click to add it, entering the access code when prompted
Manual Addition (Bind with Access Code)¶
If automatic discovery doesn't work (VPN, remote, bridge mode):
- In Bambu Studio, go to Device → Add Printer
- Select Add printer by IP (or Bind with access code)
- Enter the IP address of your Bambuddy server
- Enter the access code (8 characters)
- The printer will be added to your device list
Bind/Detect Ports Required
The "bind with access code" handshake uses port 3000 or 3002 (depending on your slicer version). Bambuddy listens on both. Make sure these ports are reachable from the slicer (firewall, port forwarding, Docker port mapping).
Sending Prints to Bambuddy¶
Server Modes (Immediate / Review / Print Queue)¶
Use Send, Not Print
You must use the Send button, not the Print button!
- Send → Transfers the file to Bambuddy (correct)
- Print → Attempts to start printing immediately (won't work — there's no real printer)
- Slice your model as usual
- Select "Bambuddy" from the printer dropdown
- Click the Send button (next to the Print button)
- The file will be transferred to Bambuddy
What Happens Next:
- Immediate: The file is automatically archived
- Review: The file appears in Pending Uploads for you to review, assign to a project, add notes, or queue for printing
- Print Queue: The file is archived and added to the print queue as an unassigned job
Send Button Location
In Bambu Studio/OrcaSlicer, the Send button is typically a small icon next to the large Print button, or accessible via the dropdown arrow on the Print button.
Print Queue mode: Force color match¶
When Print Queue mode is selected, two toggles appear on the VP card:
- Auto-dispatch (on by default) — controls whether the queued job starts automatically or sits as
manual_startuntil you click Start. - Force color match (off by default — opt-in) — when on, Bambuddy parses the per-slot filament requirements out of the sliced 3MF at upload time and pins them onto the queue item. The scheduler then refuses to dispatch onto a printer that does not have the exact filament type and colour loaded.
Why this is opt-in. Without Force color match, the scheduler still validates filament type when the job is "Any [model]" assigned (so a PLA job won't auto-dispatch onto a printer with only PETG loaded), but it does not check colour — the first available printer of the target model wins. This matches Bambuddy's behaviour before the toggle existed; turning it on is strict enough that it can leave a job sitting in the queue if no printer has the right colour loaded, which is sometimes what you want and sometimes not.
When to turn it on. If you have multiple printers of the same model and care about colour accuracy — e.g. you don't want a job sliced for matte white PLA running on a printer that has black PLA loaded just because it happens to be free first.
When to leave it off. If your fleet runs the same colour on every printer of a given model, or you reload colour by hand and want the queue to keep moving regardless.
Per-VP setting (so different virtual printers can have different policies if you have a "best-fit" VP and a "first-available" VP). The default for new and existing virtual printers is off — no behaviour change for upgraders.
Live target-printer mirror in non-proxy modes¶
If you set a target printer on an Immediate / Review / Print Queue VP, the slicer sees the target printer's live state through the VP — AMS slots, FTS / dual-extruder routing, k-profiles, nozzle / bed / chamber temperatures, lights, and camera. AMS load / dry / calibration commands the user issues from the slicer pass through to the real printer. The slicer behaves as if it were directly connected to the real printer for reads and device management, while file uploads still terminate at Bambuddy and feed the queue / archive / review workflow. No second MQTT session is opened on the printer — the bridge fans out from Bambuddy's existing per-printer subscription, so the firmware in-flight budget is not affected.
This is what makes it possible to slice an FTS / dual-extruder file with the VP selected as the active device — Studio reads the target printer's nozzle diameters, AMS contents, and FTS ID through the VP and bakes the right values into the .3mf. The earlier guidance "don't slice with the VP active" no longer applies when the VP has a target printer set.
Setup: in Settings → Virtual Printer, set the target printer for each Immediate / Review / Print Queue VP. The bridge starts automatically.
Access-code requirement for camera. The slicer authenticates the camera RTSPS stream with whatever access code is stored in its profile for the device it bound to. For the camera to authenticate against the real printer, the VP's access code must match the target printer's LAN access code. Set them equal in Settings → Virtual Printer, then re-add the VP in the slicer so it picks up the new code. MQTT and FTP work either way; only the camera path needs the match because RTSPS auth happens between the slicer and the real printer's broker.
If you don't want a live mirror. Leave the target printer unset, or use the VP without binding it to a real printer at all. The slicer will see synthetic stub state and you set filaments manually — the original "file receiver" behaviour, useful when you want to slice for a class of printer without picking a specific one yet.
If you want the slicer to be in continuous live contact with a real printer — including for slicing-time hardware fields — use Proxy Mode, not a server-mode VP.
Proxy Mode¶
In Proxy mode, you use the slicer normally — slice, select the printer, and click Print or Send just like you would with a local printer. Bambuddy relays everything to the real printer transparently.
Proxy Mode — Remote Printing¶
NEW FEATURE
Proxy Mode enables remote printing from anywhere in the world through a secure TLS relay.
What is Proxy Mode?¶
Unlike the server modes that archive files locally, Proxy Mode forwards your print jobs directly to a real Bambu Lab printer. Bambuddy acts as a secure relay between your slicer and your printer.
- Select the target printer in Bambuddy settings (must be in LAN mode)
- For cross-network: select the slicer network interface for SSDP relay
- Enable the proxy — printer appears in slicer discovery via SSDP
- Connect using the printer's access code
- Print as normal — traffic is relayed through Bambuddy
Proxy Mode Ports¶
| Protocol | Bambuddy Listen Port | Printer Port | Purpose |
| Bind | 3000, 3002 | — (local) | Slicer bind/detect handshake (served locally) |
| MQTT/TLS | 8883 | 8883 | Printer control & status (TLS-terminated, IP rewriting) |
| File Transfer | 6000 | 6000 | File transfer tunnel (transparent proxy, end-to-end TLS) |
| RTSP Camera | 322 | 322 | Camera streaming (transparent proxy, end-to-end TLS) |
| FTP/FTPS | 990 | 990 | FTP control (transparent proxy, end-to-end TLS) |
| FTP Data | 50000-50100 | dynamic | FTP passive data (transparent proxy) |
| Proprietary | 2024-2026 | 2024-2026 | Slicer–printer communication (A1/P1S, transparent proxy) |
Key Benefits¶
| Feature | Description |
| End-to-end TLS for FTP, file transfer, and camera; MQTT TLS-terminated for IP rewriting | |
| Your data never touches third-party servers | |
| No additional passwords — use your printer's access code | |
| FTP, MQTT, file transfer tunnel, camera, and bind protocol | |
| RTSP camera feed proxied for X1/H2/P2 series (port 322) | |
| Real-time status showing active connections |
FTP Data Channel Security
Bambu Studio's FTP implementation does not encrypt the data channel — even though it negotiates PROT P (encrypted), it sends file data in cleartext. The MQTT control channel (commands, status) is fully TLS-encrypted.
What this means: Your 3MF print files are transferred unencrypted between the slicer and Bambuddy. Between Bambuddy and your printer, the data channel encryption depends on the printer model (some use PROT P, some use PROT C).
Recommendation: When using Proxy Mode over the internet, place a VPN (WireGuard, Tailscale, or similar) between your slicer and Bambuddy to protect the FTP data channel.
Requirements¶
Printer Requirements:
- Bambu Lab printer in LAN Mode (Developer Mode)
- Printer must be accessible from Bambuddy on your local network
- Printer's IP address and access code
Network Requirements:
- Bambuddy server accessible from the slicer (same LAN, VPN, or internet)
- Ports 3000 + 3002 (bind), 990 (FTP), 6000 (file transfer), 8883 (MQTT), 322 (RTSP camera), 2024-2026 (A1/P1S proprietary), and 50000-50100 (FTP data) reachable from the slicer
- Static IP or dynamic DNS for your Bambuddy server (if remote)
Supported Network Configurations:
| Setup | SSDP Discovery | Manual Add | Notes |
| Same LAN | Automatic | Yes | SSDP broadcast reaches slicer directly |
| Dual-homed (2 NICs) | Automatic | Yes | Use Network Interface Override to select correct NIC |
| Docker host mode (Linux) | Automatic | Yes | Host networking passes SSDP traffic |
| Different VLANs (routed) | Automatic | Yes | SSDP cross-subnet listener responds to M-SEARCH from any interface |
| Docker bridge mode | Not available | Required | Bridge networking blocks UDP multicast |
| VPN (tun mode) | Not available | Required | Tun VPN tunnels don't carry UDP broadcast; use manual add |
| VPN (tap mode) | Automatic | Yes | Tap mode bridges L2 traffic including broadcasts |
| Port forwarding / internet | Not available | Required | SSDP is local-network only |
Setting Up Proxy Mode¶
Step 1: Complete Platform Setup¶
Make sure you've completed the Platform Setup for your installation (iptables rules, firewall ports, Docker config).
Step 2: Configure Remote Access (if needed)¶
To access from outside your home network, forward these ports on your router:
| External Port | Internal Port | Protocol | Destination |
| 3000 | 3000 | TCP | Bambuddy server IP |
| 3002 | 3002 | TCP | Bambuddy server IP |
| 990 | 990 | TCP | Bambuddy server IP |
| 6000 | 6000 | TCP | Bambuddy server IP |
| 8883 | 8883 | TCP | Bambuddy server IP |
| 322 | 322 | TCP | Bambuddy server IP |
| 50000-50100 | 50000-50100 | TCP | Bambuddy server IP |
Recommended: Use a VPN
For best security, use a VPN like Tailscale or WireGuard between your slicer and Bambuddy. This encrypts all traffic including the FTP data channel (see security note above).
Other options:
- Cloudflare Tunnel — Free tunneling (TCP passthrough for ports 3000, 3002, 990, 8883, 50000-50100)
- nginx/Caddy/Traefik — Reverse proxy for web UI only; FTP/MQTT/bind need direct access
Security Note
These ports will be exposed to the internet. The MQTT and FTP control channels are protected by TLS encryption and your printer's access code. The FTP data channel is not encrypted on the slicer side — use a VPN for full encryption.
Step 3: Enable Proxy Mode in Bambuddy¶
- Go to Settings → Virtual Printer
- Select Proxy mode from the mode options
- Select your Target Printer from the dropdown
- Click the toggle to Enable Virtual Printer
- Verify the status shows "Running" with the proxy ports
Step 4: Configure Your Slicer¶
In Bambu Studio or OrcaSlicer:
- Go to Device → Add Printer → Add printer manually
- Enter your Bambuddy server's IP or hostname
- Enter your printer's access code (not a Bambuddy password)
- The printer should connect and show as online
Step 5: Print!¶
Select a model, slice it, and click Print. The job will be:
- Sent to Bambuddy (encrypted via TLS)
- Relayed to your printer on the local network
- Started on your printer just like a local print
Dual-Homed (Cross-Network) Setup¶
For setups where Bambuddy has interfaces on two networks (e.g., printer on LAN A, slicer on LAN B):
- Enable the virtual printer, then select the slicer-facing interface under Network Interface Override
- Bambuddy will re-broadcast printer SSDP on the slicer's network
- The slicer discovers the printer automatically via SSDP
- All protocols are proxied including camera streaming (RTSP port 322) — no additional NAT rules needed
Proxy Mode vs Server Modes¶
| Feature | Immediate | Review | Print Queue | Proxy |
| Files stored locally | Yes | Yes | Yes | No |
| Sends to real printer | No | No | No | Yes |
| Remote printing | No | No | No | Yes |
| Requires target printer | No | No | No | Yes |
| Uses printer's access code | No | No | No | Yes |
| Requires Bambuddy access code | Yes | Yes | Yes | No |
Slicer Can't Find or Connect to Virtual Printer¶
- Check virtual printer is enabled and showing "Running" status in Bambuddy Settings
- Verify bind/detect ports are reachable — the slicer needs port 3000 or 3002 for the handshake:
- Check firewall — ports 3000/tcp, 3002/tcp, 2021/udp, 8883/tcp, 990/tcp, 2024-2026/tcp, 50000-50100/tcp must be open
- Same network? — SSDP discovery only works on the same LAN/subnet. Use "bind with access code" for VPN, remote, or Docker bridge setups
FTP Error / Connection Reset¶
- Check permissions on the uploads directory
- Check no other FTP server is using port 990
- Verify
CAP_NET_BIND_SERVICE— the process needs this capability to bind to port 990 - Review logs for specific error messages
"Wrong Printer Model" Error¶
The slicer's selected printer profile must match the virtual printer model in Bambuddy settings.
Permission Denied Errors¶
If you see "Permission denied" in the logs:
# Fix ownership of the virtual printer directory
sudo chown -R $(whoami):$(whoami) /path/to/bambuddy/data/virtual_printer
Authentication Failed¶
- Verify access code matches in both Bambuddy and slicer
- Access code must be exactly 8 characters
- Try removing and re-adding the printer in your slicer
Wrong IP in SSDP / TLS Handshake Fails (Multi-NIC)¶
If Bambuddy has multiple network interfaces (LAN + VPN, Docker bridges, etc.), the auto-detected IP may be on the wrong interface:
- Enable the virtual printer if not already enabled
- Under Network Interface Override, select the interface your slicer connects through
- The virtual printer will restart with the correct IP in SSDP broadcasts and TLS certificate
TLS Connection Failed / Error -1¶
This typically means the slicer doesn't trust the virtual printer's certificate.
Linux AppImage / Flatpak users — start here
The printer.cer shipped inside an AppImage or Flatpak is read-only, so editing it in place isn't possible without extracting the bundle. Recent Linux builds have tls_cert_store_accepted: yes set in BambuStudio.conf, which means the slicer trusts the system CA bundle. Install the Bambuddy CA there instead — see the Linux tab in Step 2.
Verify Bambuddy CA is in slicer's certificate file:
The count should be higher than a stock install (stock has 1 certificate). -
Wrong certificate? If you have multiple Bambuddy hosts or reinstalled, you must update the certificate. See Step 2.
Verify certificate fingerprints match:
Verify this fingerprint appears in one of the certificates in your slicer's# On Bambuddy server (Docker) docker exec bambuddy openssl x509 -in /app/data/virtual_printer/certs/bbl_ca.crt -noout -fingerprint -sha1 # On Bambuddy server (native) openssl x509 -in virtual_printer/certs/bbl_ca.crt -noout -fingerprint -sha1printer.cer. -
Fully restart the slicer — Cmd+Q on macOS, or End Task on Windows. Just closing the window is not enough.
Regenerate certificates (last resort):
You'll need to remove the old Bambuddy CA from the slicer and append the new one.
Proxy Mode: Printer Shows Offline in Slicer¶
- Verify the target printer is online in Bambuddy
- Check that the printer is in LAN mode
- Restart the proxy by toggling it off and on
Proxy Mode: "Connect Using IP and Access Code" Dialog When Printing¶
If the slicer connects and shows printer status but shows a connection dialog when you click Print:
- Check port 6000 is reachable — BambuStudio uses this port for the file transfer tunnel:
- Check firewall — port 6000/tcp must be open between slicer and Bambuddy
- Different VLANs/subnets — the MQTT IP rewrite ensures the slicer connects to the proxy, not the printer. Check Bambuddy logs for
IP rewrite activeto confirm it's working
Proxy Mode: Camera Not Loading¶
- X1/H2/P2 series: Camera uses RTSP on port 322. Ensure this port is reachable from the slicer
- A1/P1 series: Camera uses port 6000 (shared with file transfer). Ensure port 6000 is reachable
Proxy Mode: Connection Drops During Transfer¶
- Large files may timeout on slow connections
- Check your internet upload speed
Technical Details¶
Security¶
- Bind protocol (ports 3000, 3002): In proxy mode, Bambuddy responds with the VP's own identity (not forwarded to printer). Unencrypted TCP — transmits printer identity only, no sensitive data
- MQTT control channel: TLS-terminated at Bambuddy (TLS 1.2). In proxy mode, printer IP addresses in MQTT payloads are rewritten to prevent the slicer from bypassing the proxy
- File transfer tunnel (port 6000): End-to-end TLS (transparent proxy)
- Camera streaming (port 322): End-to-end TLS RTSP (transparent proxy)
- Proprietary ports (ports 2024-2026): End-to-end TLS (transparent proxy). Used by A1/P1S models for slicer–printer communication
- FTP control channel: End-to-end TLS (transparent proxy)
- FTP data channel: In proxy mode, transparent proxy — encryption depends on slicer/printer negotiation. Bambu Studio does not encrypt the data channel. Use a VPN for end-to-end data encryption
- Self-signed certificates are auto-generated (shared CA persists, per-instance device cert regenerates per serial)
- Access code authentication required for all connections (8 characters)
- Certificates stored in
virtual_printer/certs/(shared CA) andvirtual_printer/certs/{id}/(per-instance certs)
Limitations¶
- Each virtual printer requires its own dedicated bind IP address
- SSDP discovery requires same LAN or routed subnets — use manual IP entry for tun-mode VPN, or Docker bridge setups
- Slicer must trust the self-signed certificate (see Certificate Installation)
- FTP data channel unencrypted on slicer side (use VPN for full encryption)
- VPN tun mode does not support SSDP broadcast — printers must be added manually by IP
